Question about Kenneth Cole 1213 Wrist Watch
The buckle fell off the band
The buckle literally came apart and fell off the band. Tried to find a replacement buckle and it is apparently like 24mm and the standard largest size at a jewelers is 22mm. I t just really ticks me off. Went back to the store of purchase and the best they will do is exchange me another watch which is completely different. This watch was the wedding gift I bought my husband and I don't want another watch. He had only worn it twice before it broke.
    Problem Solver:
  • 19 Answers
Hi Kap2000
I know it's frustrating and I work in the industry the only thing I can suggest is to a Contact the manufacturer directly or try ebay for replacement bands? and Then rob the buckle off the new one to fit the old, so you still have the gift you gave to your husband?
Model numbers would be useful if you wanted to email me I can try and help out further? (however in australia!)
Posted on Jul 14, 2009
I need a pin and buckle for 45/7053 m1099 watch.
Hello, Jennifer -
Are you asking about a band for the Armitron M1099 women's wrist watch?
By "pin and buckle" are you referring to the closure part of the watch band and/or one of the thin metal rods which attach the watch band to one end of the watch?
If I am correct in my guess about a replacement band or parts of a band for an Armitron M1099 women's wrist watch, if you have not already contracted Armitron directly about the needed parts, this is the link to the Armitron Watches web page regarding Service Centers:
https://www.armitron.com/pages/service-centers
Near the bottom of that web page, you will see a list of authorized service centers. I suggest you make a telephone call to one nearest where you reside and ask about the replacement parts you need before sending it (insured) for repair. Note: Also ask about the estimated repair cost.
Best wishes.
Apr 02, 2018 | Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    Replacement watch band
    You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
    Mar 30, 2010 | Oakley Watches
    How to take the buckle off the leather strap from cartier leather strap
    I will give you the generic answer as I have not actually removed a Cartier buckle. Most buckles use a small bar called a spring bar that goes through the band and "tang". The ends of the bar are like a plunger in that with a small fork like instrument or small screw driver you can collapse the bar and move it out of the clasp. The rest is very obvious. Replacement is the opposite of removal. A fairly simple procedure for most people.
    Nov 12, 2009 | Cartier Roadster W62019X6 Wrist Watch
    I HAVE KC 3500 WATCH.MY BAND IS IN TERRIBLE CONDITION.
    You do not need exactly the Kenneth Cole watch band. Measure the distance between watch case lugs - this will be the width of your new band. Go to any jewellers shop you like, ask them to show all watch bands of this size and choose whichever you like. Ask them to fit it as well if you do not fancy to do it yourself.
    In case if you have a buckle with KC logo and want to keep it, then take it with you and ask to refit the buckle as well.
    Rate me, please.
    Mar 12, 2009 | Kenneth Cole RK5034 REACTION
    Anne Klein 10/5875 Y121E
    You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
    You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
    Do not forget to rate, please.
    Feb 27, 2009 | Anne Klein 108293SVBK Watch
    Watch band repair
    See if the buckle does have spring loaded pin like the ones that hold the band to the case.
    Mar 28, 2008 | Watches
    Kenneth Cole 1213 Wrist Watch Logo
    142 people viewed this question
    Top Kenneth Cole Watches Experts
    Ansel Alberto
    Ansel Alberto
    Robby Otts
    Robby Otts
    Level 1 Expert
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
