Question about Amana RanARG7302 Gas Kitchen Range
Oven works when it feels like it.
Our Amana stove has been acting up for a few months. At first it was always 40-60 degrees off in temperature, but then it started only heating to 150 or 200 degrees and getting no hotter no matter how long you waited. The next day it worked fine, so today(about three days later) I tried to heat it up and it got to 200 degrees, then started dropping. Also I smelled gas strongly. I turned it off and let it cool down, then I tried again. This time it heated perfectly, to the exact temperature on the dial. I finished with it, turned it off, it got cold. Then I needed it again, so I turned it on again, same day, and it got to about 150 and I smelled gas, so I right away turned it off and back on, and it heated fine again. What in the world is wrong with this oven???!
  • marda98 Mar 15, 2008
    I have the same problem, not knowing anybetter I turn on one of the burners on top and works fine.
    Problem Solver:
  • 10 Answers
Your limit switch not working
Posted on Aug 17, 2008
  • 473 Answers
The ignitor is weak and not lighting the oven consistently. Need to replace the ignitor.
Posted on Nov 16, 2007
My Amana PTAC set to 90* blows cold air then warm then back to cold. The temperature outside is just a few degrees
sounds like the auxillary heat strips are coming on and off....what kind of time does it cycle on and off?
Feb 16, 2015 | Amana Heating & Cooling
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
Oven not heating to desired temperature
You will have to place a amp meter over one ignitor wire and turn the oven on to bake.
If the amp draw is 3.3 amps or less,replace the ignitor.
Jul 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Jun 27, 2009 | Ovens
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Heat pump works in emergency heat, but not in auxiliary heat
I set the thermostat for 70 degrees. It comes on always in auxillary heat and does not shut off when it reaches 70 degrees. It is a heat pump, I am assuming, it might be the thermostat? But when the air conditioner is on, it turns off when it reaches it's temperature.
Jan 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
Amana RanARG7302 Gas Kitchen Range Logo
223 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
