Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
2000 25hp Kohler V-Twin will not start when key is turned to run position. Currently using a push button switch to start engine. Replaced: ing.switch,ammeter,starter with new sol.,all safety switches.
  • jbmike7 Jul 14, 2009
    Problem is not running, it starts and runs fine. Just not with the key turned to the run position. I have to use a push button switch with the key on the start position to get it to start up.
    President:
  • 2,187 Answers
It sounds like a wiring issue when you read the problem. I would assume that when all of the electrical components you mentioned were replaced the terminals and connector should be all oK. Each position in the key except for off should have a contact. I suspect the wiring on the run may be the culprit. Since the key was replaced, I supposed that the contacts are no longer an issue. Check for the ground connector and exposed wires.
Posted on Jul 14, 2009
  • 3,230 Answers
It looks like that engine should have a fuel shut off soleniod if it does it would be what holds the carb bowl on and have one wire coming out of it. If it has that check the wire it should have 12 volts when the key is turned on. And you should be able to hear or feel it click or snap when you turn key on and off. If that looks good or does not have it check bowl for gas and let me know what you find.
Good Luck!!
Thanks
Have a kohler 27 on scag turf tiger the engine will turnover then the starter begins to click and will not start any suggestions
Check the oil for fuel in it. Oil will be really thin and be over filled. Take out the spark plug and see if excess fuel is pushed out when you crank it. If there is then the fuel shut off solenoid on the bottom of the carburetor is leaking fuel into the engine when it's not running.
Oct 01, 2014 | Kohler Command Pro V-Twin Vertical Engine...
Kohler engine troubleshooting
First thing to check is manual start with a rope if there is one. If you can start it, then it is the battery or cables. If you can not start it then check to see if the blades and or transmission is disengaged. If they are then the engine is seized.
Jul 29, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Starter clicks when you push starter button
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Feb 18, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to test a crank position sensor
Turn the key in the ignition to the "Off" position. Turn the "Run/Stop" switch to "Run." Push and hold the odometer "Reset" button. Hold the "Reset" button and do not release it yet.
Turn the key to "Ignition," but don't start the engine. Release the odometer "Reset" button. Wait for the odometer to indicate the bike is in diagnostic mode by displaying "Diag." Push the odometer reset button and then release it when you see the "P" in the menu selection flashing.
Wait for the bike to complete the diagnostic of the electronic control module and the ignition control module. Write down the codes that are displayed after the diagnostic is complete. Code PO 374 indicates a failed or faulty crank position sensor due to a synchronization error.
Feb 08, 2014 | Harley Davidson Motorcycles
Bad ingition switch, how to Bypass till replaced
Turn key to on position
If the radio and blower work then run a jumper wire to the ign side of the starter solenoid(small purple wire). Hook it to a push button switch which has 12v on feed side. Push button to start.
If no power is on with key on you will need to feed the fuse box with a 12v feed from the battery.
Oct 02, 2013 | 1985 Chevrolet K1500
2001 flstf will not crank
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
May 18, 2012 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
3 year old Toro Z4200 time cutter Z, 19 HP Kohler, engine runs great, new battery, new solenoid, with the seat sensor connected or by-passed, STILL WONT start off the key switch. Clicks at the kill relay....
My tractor is doing the exact same thing now. Did you ever get this problem figured out? I figure it to be a grounding problem, a short, or this "kill relay" problem.
Aug 23, 2010 | Sport & Outdoor - Others
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
Old style starter relay wiring
Normally on the old style starter solenoid/relay you have two large bolts for the battery and starter cables to attach to. There are two other smaller bolts that are used for the starter actuation. The "I" is used to add voltage to the points so the engine will start while the solenoid is in the start position, the other "S" goes to the start button or start side of the ignition switch. Old style ignitions used to drop the voltage to the coil during start and the engine would turn and turn until the key was released and then the engine would catch and start. To cure this they made the solenoids were designed to give temp power to the ignition system when cranking and starting. Hope this helps, RAC
Apr 13, 2009 | 1985 Ford Mustang
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
