Question about Jenn-Air JCD2389G Side by Side Refrigerator
Refrigeration side not cold - freezer fine
Why would the refrigeration side not work well and the freezer is working fine? odd.
any ideas?
anything i can myself to try to fix this?
    Scholar:
  • 86 Answers
Please remember the refrigeration side is a empty box the cooling is coming from the freezer side using a fan blowing through a hole cover by a slide and you can slide this cover wide open for colder in the refrigeration side or less as you wish. Hope this can help. God Bless.
Posted on Jul 14, 2009
Thr fridge side is not cold the freezer side works fine
that might just mean the tempature dial needs turned up 1 number say from 4 to 5 or 5 to 6 try it and check temp in refrigerator often if that doesn't help then you might need a refrigeration serviceman
Mar 13, 2015 | Refrigerators
FREEZER WARM AND ICE MAKER DOES NOT WORK
ice maker will not work if freezer is not at the right temperature. Refrigeration problem or refrigeration control problem. Might need to seed refrigeration technician. good luck.
Jun 25, 2014 | KitchenAid KSCS25FKSS Side by Side...
Just moved into new house. Freezer wont get cold. Temp display is flashing. samsung rs2520sw. Fridge side working fine
The compressor probably needs re-gasing. You will need a refrigeration engineer.
Good luck
Aug 05, 2011 | Samsung Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator is not cold enough
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 03, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
Sister has Montgomery ward upright freezer, she had 3-in-1 part installed compressor runs now but she called and said freezer is not getting cold, water in cup still not frozen after 1 day. Is there a way...
Don't know three in one is, capacitor?
The compressor has oil in it. If the unit is layed on its side, compressor oil can leak out into the refrigeration tubing. This can cause a refrigeration circuit clog. Leaving the unit disconnected, upright, for a few days, sometimes fixes this oil clog.
If it sprung a refrigeration leak, it's another story, it needs a service tec looking for a leak. Then repairs, just chuck it or invest in this nice unit on repairs.
If compressor and fan blowers all run and work, the electric portion is good, compressor line gets hot, the other one cold.
Aug 25, 2017 | Freezers
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Kenmore 52282 / 52284 Side by Side...
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
272 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
