Question about Whirlpool Calypso GVW9959K Top Load Washer
What is the L5 signal - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
What do these numbers appeared when i was trying to reset regular maintance service light
did you look in the operatrors guide, in the glove box yet>
that is always first.
codes can be , service required, Oil changes, etc. then you reset it per said book'
or can be failures. (hard failures)
that is why we look first.
2008 volvo T5 or T2.5?
146
Immobilizer Communication. Signal Missing
046 , air bags?
this car, like mine can produce 1000s of DTC codes.
what WE do , is use a real scan tool to see real codes.
for example the 167 my show up as
ECM-710B/U0167 (2.5L L5 VIN 59 Auto) or
Trouble Code: ECM-92CC/P1167 (2.5L L5 VIN 59 Auto)
bad throttle
USE a real scan tool or its IMPOSSIBLE.
May 03, 2014 | 2008 Volvo S60
Speed sensor L5
follow this steps and fix it. God bless you
SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement
This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board.
NOTE: USE THIS FOR DIAGNOSING THE PWM/RELAY COMBO BOARD
Oct 21, 2013 | Landice Exercise & Fitness
I have York intensity treadmill and its not working, the L 5 keeps showing on screen.
Test the input voltage 2)test the relais 3)see sensor speed wiring 4) test terminal motor.
God bless you
Oct 09, 2013 | York Exercise & Fitness
L 5 -- low speed
hi, pls check speed controller
Dec 05, 2010 | Sole Fitness F83 Folding Whisper Deck...
Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
GETTING A ERROR L
L1 = Mirror feed trouble,check the mirror motor.
L2 = Mirror motor lock
L3 = Mirror returntrouble
L5 = Lens trouble,check the lens motor,sensor and driver board.
L6 = Rotary casette trouble
L8 = Full wave signal error
L9 = Sorter trouble.
Nov 24, 2009 | Sharp AL-1642CS Copier
How do you wire l5 to 2 ohm
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Sep 19, 2009 | Kicker Solo-Baric L5 Car Subwoofer
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Whirlpool Calypso GVW9959K Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
