Question about Samsung SPP4231 42 in. EDTV-Ready Plasma Television
Horizontal Shaking lines on picture
Mine does the same but now it shakes instantly, however if i leasve it on long enough picture gets normal. prioblem doesnt seem to be heat or overheat related i cant seem to figure out any pattern causing the problem
  • 304 Answers
The two parts that could be causing the problem are the Main bd and the P-Logic bd.
Posted on Jul 16, 2009
The screen on my sanyo box TV model number DS27510 starts shaking and the picture starts cutting in and out anyway to fix??
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 10, 2016 | Sanyo Televison & Video
Hayward 100 pool heater shaking
Not enough water flow!
Either a
  • bypass valve is open all the way, and reducing water flow into heater
  • Worn/broken internal bypass - unitherm governor
  • Blockage of some sort reducing water flow, in circulation line
When something like the above is present, the minimal water flow, gets super heated really fast when heater is on and firing! So hot in fact, that the water turns to Steam Instantly!
and the steam is a very Volatile substance! Remember? It was once used to move Locomotives!
get this fixed asap!
call a pool / spa professional for assistance in evaluating your next step.
Good Luck.
Jun 23, 2014 | Hayward Pool & Spa
Horizontal shakes
degauss comes to mind... when older monitors build up magnetic field it distorts thic picture and a degauss shakes/scrambbles the screen and gives a nice *thongggg* sound that eleminates the disruptive magnetic build up. (or something)
only flaw with this answer is you usually degauss on purpose.... never seen a monitor degauss on its own, and only old projection style monitors worry about this
more info on degauss (really interesting stuff!)http://en.wikipedia.org/wiki/Degaussing
Nov 22, 2013 | Office Equipment & Supplies
Vizio VO370M LCD TV screen is mostly black with green/blue horizontal stripes at the to. How can I fix this?
Most likely you are looking at a defective LCD panel, but I would recommend getting a proper diagnosis.
Sep 07, 2012 | Vizio VO370M LCD TV
I have amonitor 32 inch when i turn it on i see meany horizontal lines this lines colored how can i solve this proplem pls?
Hello When you get horizontal line, especially colored, it typically means there is a problem internally: either with the LCD inverter (backlight), LCD Circuit board (interprets incoming signal) or the Display panel itself. Sometimes shaking it around can clear up the issue slightly but for the most part it's time to get a new screen. If you have pictures I can verify this is the issue. Any other questions, feel free to ask.
May 13, 2011 | Polaroid Computers & Internet
I am 66 yrs old..my hand shakes normally...what is the best (least expensive) camera to deal with my shaking hand...very important to me to get clear pictures any help would be appreciated
You could use a tripod with a camera that has a cable trip connected to it, so your hand can shake, but it won't shake the camera at all.
An SLR Digital camera is likely to have the ability to reduce the shaking using this method.
Or, a higher end camera with anti shake circuitry would help.
Aug 13, 2010 | Cameras
Picture shakes and hass horizontal lines
The chassi will need to be removed and sent to Mitsubishi to be rebuilt.
Mar 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV picture is shaking up and down.
Try unplugging any devices near the TV one by one and see if that helps.
I had the same problem with my picture shaking on all HD channels and found that it was my land line phone interfering with the signal.
Hope that helps!
Dec 11, 2009 | Samsung LN46B640 LCD TV
make sure the cable ord in the back is plugged in right
Dec 11, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Nov 10, 2007 | Samsung Digimax S800 Digital Camera
Samsung SPP4231 42 in. EDTV-Ready Plasma Television Logo
313 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
