Question about Samsung Yepp YP-T7JZ MP3 Player
My samsung yp-tyj mp3 will charge but wont turn on!
Ive tried to reset it but it still wont turn on afterwards. still charges up but just wont cut on
Why don't you just take it to Best Buy2.gif or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 26, 2007
SOURCE: Samsung YP-U2JQB MP3 Player
Can I post a solution without being registered?
Posted on Aug 05, 2008
  • 4 Answers
SOURCE: Samsung YP-K3 MP3 Player won't start
Simalar problem to all above plus PC would not recognise the unit when connected. Solved however by going into Device Manager on PC, uninstalling it and then plugging back into PC. As it is all plug and play it took it as a new device and everything working perfectly again.
Posted on Aug 24, 2008
SOURCE: I lost the installation cd for my YP-K3 mp3 player... what to do?!!
Pls. help me to install my yp-k3 player
Posted on Oct 24, 2008
  • 3 Answers
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Posted on May 13, 2009
SOURCE: My Samsung YP-T9 MP3 Player wont turn on!!
press (rec+menu ) for trnin on the mo4 ! i just know it ! but for me doesnt charg and connect to computer ! i dont know what should i do !
Posted on Nov 16, 2009
0 characters
1 Points
My mp3 player is frozen
Please do hard reset by turn it off / or remove the battery
Jan 29, 2011 | Samsung YP-U3 MP3 Player
My samsung yp k3 has been charging for about 3 days now but it wont turn on, anyone know what to do?
It's been charging, but it won't turn on?
Okay, well, you can always get a toothpick and press the "reset" button in back.
Happens to me all the time.
The reset button won't delete your stuff, it will just turn it back on.
The reset button is on the back of the mp3 in the lower right hand corner. use a toothpick, and just press it.
After that, the mp3 SHOULD turn on manually.
Jan 02, 2011 | Samsung YP-K3 MP3 Player
Mp3 wont respond to anything...
did you try the tiny reset button on the back?...You have to use a pin to reset. This happened to me and it worked. Good Luck!
Jun 07, 2009 | Samsung YP-K3 MP3 Player
Mp3 wont turnn on
try using a different computer i had the same problem
Jan 31, 2009 | Samsung YP-U3 MP3 Player
My samsung mp3 went though the washing machine and wont turn on.
Might be a lost cause, but you could try putting it in a bag of dried rice. Maybe for a day or two. You should have done this right after it came out of the washer so I'm not sure it will do anything. It's worth a try though.
Jan 17, 2009 | Samsung Yepp YP-T9 Digital Media Player
Doesnt work
ok well first u hold the rest button for 10 seconds then let it charge on a diffrend computer for 4 hours
Mar 24, 2008 | Samsung YP-K3 MP3 Player
Dec 25, 2007 | Samsung YP-K3 MP3 Player
the same thing happens to mine! it sucks
until, i phoned up samsung..they said put it in the freezer. i know it sounds silly but by putting it in the freezer the cold air allows the electrical particles to become free due to the negative charge present. (i researched a lot) do it for 24 hours-25hours no more than the reset button afterwards! mine totally worked normally again.
Nov 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
My samsung K3 wont turn on.
Maybe you have a USB 1.1 on your computer. YP K3 will charge much faster on USB 2
Nov 02, 2007 | Samsung YP-K3 MP3 Player
Samsung Yepp YP-T7JZ MP3 Player Logo
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
