Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
Brand new ice maker, water fill to tray will not shut off
I took the cover off, there is nothing inside except the wheel that operates the shut off arm. No data, no timer to adjust, nothing.
So, when I turn the water on to the ice maker line, the tray fills and the water then over flows into the ice box.... unless I turn off the water supply valve each time I fill the tray. Ugh!
Ideas?
  • Whirlpool Master
  • 4,654 Answers
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Posted on Jul 14, 2009
  • 358 Answers
The water valve (bottom back of the refrigerator) is leaking.
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
(REFRIGERATER or ICEMAKER)...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Ice Maker is not dispensing ice
Since it is brand new, it should be covered under warranty but check a few things first. To make ice, you need to have the water, a cold freezer, and the ice maker must be turned on. Since you say you have ice then the temp and the water supply sound OK. There is a shut off option on ice makers so you can decide not to make ice as on option. Check that the ice maker is turned ON. Also, there is an automatic shut off if the bin fills up with ice so it does not overflow. On mine, it is a bar that will raise up higher as the ice accumulates and that will shut off the icemaker. Check that. Otherwise call GE for warranty service on the icemaker.
Jan 14, 2014 | GE Stainless Steel French Door...
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
My 642 stopped making ice; I took the and cover/rear plate off so I could see what was happening ice-maker-wise. I saw no water in the maker. I realized a plumber had (possibly; I'm not 100% sure)...
You may have an ice plug frozen in the fill tube, for that use a hair dryer to try and unfreeze the ice plug. Be sure the mechanism is actually working. A clock mechanism rotates a cam on the front of the icemaker that hits a micro switch for a period of tme that operates a water solenoid. That solenoid pulls a plunger valve out of the water line, allowing water to flow up to the icemaker. When the cam pulls off of the microswitch, it interrupts the power to the solenoid. The plunger snaps back in the line due to a spring compressed on the first operation. If that solenoid is not getting power, then the water does not flow. The Ice full bail operates another microswitch that stops the clock mechanism from operating. If the tang on that microswitch is broken, then nothing happens.
You are going to have to determine what part is defective, the solenoid or the ice maker itself. The ice maker is the easiest to replace as it is connected by a plug and a couple of screw clamps holds it in place.
Jan 23, 2011 | Sub-Zero 642
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
667 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
