Question about Honeywell Comfort Control Tower Fan - White
My tower fan rattles. supposed to be quiet. how do i fix it?
It is impossible to take fan apart, but I have found a solution. You will need a can of WD-40, a rag, and a flashlight. Inside the fan is a tall drum that rotates, the rattle is coming from the top center of this drum, where it attaches to fan motor. Turn fan off, and put the rag on the back of the fan to avoid spraying out the other side. Use flashlight to locate the top center of the drum inside the fan, and spray with WD-40. Step back before turning fan on, or you will get oil in your face. It will take a few tries but the fan will be quiet when you hit the sweet spot.
Posted on Jun 26, 2010
    Problem Solver:
  • 4 Answers
Most fans have a sticker located on the middle of fan where the rotating impeller attaches to the fans frame. If you remove this sticker, you'll see a seal and a bearing. Put a *TINY* drop of oil on the bearing, and replace the sticker. Spin the blades to see if it gets noticeably smoother. If the sticker won't re-apply, tear it off and replace it with a hand-cut piece of clear or electrical tape that's roughly the same size and shape. I've used this method to fix fans that were almost completely seized up. For fans that are just noisy, it works almost every time. Note that if this is the CPU fan, the tape and the bearing will be on the underside of the CPU, mandating it's removal from the heat sink. If it's the Power supply fan, you will have to remove the power supply from the computer, remove the case, and undo the four screws that *usually* hold the fan to the back of the power supply's case. Hope this helps....
Posted on Jul 14, 2009
I have a rattling noise on my 2.8 mitsubhishi pajero 1997 model.the noise is at the front of the engine. i checked the timing chain and guides they look ok and tight.when i rev the noise get quiet but when...
its likely the fan. if it sounds like metal clicking or grinding, its the fan bearings.
it could also simply be the plastic fan case rattling/rubbing against another hood accessory.
Mar 18, 2015 | 1997 Mitsubishi Pajero
Honeywell Quietset
Disassemble , clean and lubracate. Replace worn parts.
www.honeywellfansavings.com/fans/customer-support/
Jul 08, 2014 | Honeywell HY-048BP Tower Fan
Rattle noise
if you just got it check for packing material stuck around the fan area
if there is nothing , then take it back for a warranty exchange as it is not as described ---quiet
Jun 26, 2017 | Honeywell Humidifiers
HELLO, The Problem I'm having is My Honda EX 800 Generator, The Problem is, it's loud and also has a loud rattle, ANY IDEA'S ????
When it comes to gas generators "quiet" is a relative term, the EX 800 is quiet relative to other gas generators yes, but is not quiet by any means. If you hear a rattle check the panels for a loose sections which you should be able to hand tighten with a screwdriver from either end of the unit.
May 16, 2012 | Honda Electrical Supplies
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
Hello i have the Honeywell Quietset 8 Speed Tower Fan. We purchased it from target last summer. It was a great working fan, loved how lightweight it was and it was extremely quiet. Not too long ago it...
The cord has a fuse at the plug. Check the fuse it could be blown. To access the fuse there is a slide open door that is about 1" x 1/4" on either top or bottom of the actual plug.
Jul 07, 2011 | Honeywell HY-048BP Tower Fan
I stupidly tried, in the wee hours half asleep, to force the fan to turn to a certain direction when the oscillation was turned off. Something broke and rattled around, and now the oscillation is...
Unfortunately, no - the manufacturer does not supply replacement parts. It is a throw-away item.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Seville Classics MSC10166 Tower Fan
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Honeywell Comfort Control Tower Fan - White Logo
6,877 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
