Question about Microsoft Xbox 360 Console
My console begins to flash one red ring when ever I plug in my AV cables and when I do it says E 73. What should I do?
    Problem Solver:
  • 4 Answers
Hey, you may wanna check this link ... it says:
"E73: I/O Hardware Error - Couldn't calibrate HSIO Bus fromedram: this error is likely caused by a problem with the Ethernet portor supporting control devices"
hope it helps...
atte>jabafreak
Posted on Jul 14, 2009
I have the red ring of death and all it says it contact microsoft
here are the first things to try for a rrod
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this doesnt fix it then you are in to taking the xbox apart, which will void any warranty you may have on it.
Dec 27, 2009 | Microsoft Xbox Console
One red ring. E 73
this is a video problem. it could be that your AV or HDMI cable is not plugged in correctly or it can be a scaler chip issue which requires an unboxing of your console to fix.
good news this error is now covered on microsofts 3 year warranty. so make sure your system is less than 3 years old, call up 18004myxbox and get if fixed for FREE.
Dec 15, 2009 | Microsoft Xbox 360 Console
Red ring of death
HI, this is a AV cable fault. it is unable to be detected. follow the procedures below to correct this issue. of the procedure dose not produce results, this will confirm that the damage is severe, and you will need to contact Microsoft for a repair ticket.
Check Points
Sep 04, 2009 | Microsoft Xbox 360 Console
4 red ligths on my xbox 360.
The AV cable cannot be detected
THINGS TO TRY
Jan 18, 2009 | Microsoft Xbox 360 Console
4 red lights flashing
CAUSE This issue may occur for one of the following reasons: The audio-visual (AV) cab... loadTOCNode(1, 'cause'); This issue may occur for one of the following reasons:
  • The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console.
  • The console is not detecting the cable.
This issue does not occur if the AV cable is plugged incorrectly in to a television, stereo, or VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port
Dec 30, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
4 red lights
Dec 26, 2007 | Microsoft Xbox 360 Console
4 RED lights
THINGS TO TRY for the ring of death!
Dec 13, 2007 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
120 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
