Question about Planar PE191M 19" Flat Panel LCD Monitor
Planar Monitor Wont stay on
I have a dell Inspiron 530 and I just bought a planar PE191m And when i pluss it in it turn it on my desktop pops up and then the screen goes black but the green like is still on and when i turn the power to the monitor off and on again it does the same thing pop up and goes black it there any way to fix this
my spec are
Genuine Intel(R) CPU 2140 @ 1.60GHz
2037mb ram
Intel(R) GMA 3000/3100 Display card
Windows Vista Home Premium 32 bit
  • 130 Answers
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
Posted on Jul 14, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I Bought two planar dome C3I , i dont have graphic card.
Only the Planar Dome DX2 card..... no other. Planar did this on purpose to sell those cards at 2k each. Now very reasonably priced on eBay, but they'll only work on XP, not W7.
Dec 24, 2011 | Planar Dome C3i 20.8" LCD Monitor
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
Planar Pe191m goes dark image seen with flashlight
I would suspect either the power suuply or inverter circuits, look for bad caps first which is common problem, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
If you want replacement lamp, you can look here, it also gives you info on how to measure the lamps dimensions: http://www.lcdparts.net/
Mar 08, 2010 | Computers & Internet
I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Feb 24, 2010 | Planar PE171 (Black) 17 in. Flat Panel LCD...
Won't stay on. When the power is turned on, an
Make sure you video cable from the computer is seated in correctly.
Dec 29, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Same issue, screen comes up for 2 seconds then blacks out
plug the screen into another pc, laptop, whatever you can find. if it still does it its the screen, if not its your video. could be a power cord, but usually not. if cheap it may be worth a gamble.
Aug 22, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Screen goes black after 2 seconds
This could be one of two problems, the light in your monitor has a loose cable, or the light is dying. I have seen cold cathode lights that are about 10-15$ to buy and many instructions on putting them in yourself.
Solution 2, your cable is loose on the back of the monitor. Make sure you have the screws tightened on either side of the vga or dvi cable, both on the back of your monitor and on the back of your computer or laptop.
Jun 28, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar PE191M 19" Flat Panel LCD Monitor Logo
353 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
