Question about Jenn-Air JFC2089HE French Door Refrigerator
Frige not cooling, freezer is fine
The temp alarm started going off and I noticed the temp in the frige section was getting warmer. The freezer still seems to be freezing. The condenser and the fans sound like they are running.
  • 583 Answers
Its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Posted on Jul 14, 2009
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Frige cool freezer warm
IS the compressor running and is it hot?
Dec 08, 2012 | Maytag MFD2560HES Bottom Freezer French...
The freezer side is working fine but the refrigerator side is warm and not cooling well
its normal for a frige to get warm when its new run wait until your evaforating section is full of ice then you will notice that side of your frige will get the normal heat.... to stay in automatic mode
Aug 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Jenn-Air JFC2089HE French Door Refrigerator Logo
387 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
