Question about Kenmore 43142 Front Load Washer
Need to change door from left hand to right hand open on kenmore HE2
Currently the doors on my Kenmore HE2 washer and dryer open opposite of what I need. Can I change the doors so the hinge is on the other side?
  • 3 more comments
  • Anonymous Apr 25, 2008
    Every wahser/dryer combo out there has the door on the wrong side for my house's configuration
  • Ditts May 06, 2008
    Need to change door from left to right hand.
  • Anonymous Jan 01, 2009
    I cannot find a front loader washer with a right-handed door.
  • Anonymous Apr 12, 2009
    need a front load washer with the hinge on the right not the left.
  • Anonymous Mar 23, 2014
    F01 Code on dryer. Won't start
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Posted on Jun 26, 2008
No.
Posted on Jan 04, 2008
Can the door on this dryer be swtiched easily? (from right to left....) Can't find manual. Thanks. MD
you can get the manual from sears or searspartdirect.com
However the door cannot be switched on most of those models.
Aug 01, 2010 | Kenmore HE2 Plus Front Load Washer
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
I have a Kenmore washer and dryer set HE2 - and would like to leave them in thier current postions. My question is can the doors be swithed to open on the other sid?
You could probably ask any salesman just act like your interested in buying it but you need it to open left handed , they.ll be more than happy to let you know how easy it is to do, or not..good luck,,l think you can do it,
Sep 18, 2009 | Kenmore HE2 Plus Front Load Washer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is stuck on spin and the door wont open. It is locked.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 16, 2009 | Kenmore HE2 Plus Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
1,630 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
