Question about Tomtom RIDER GPS Devices
Tomtom Rider GPS won't turn on
My tomtom Rider GPS was working fine earlier today on it's car mount while charging from car accessory outlet (cigarette lighter). After I turned it off and later tried to turn it on, still plugged in via accy outlet, nothing would happen when pushing start-up button. Any advice? Thanks!
  • sjf167 May 11, 2010
    Is it a TT rider1 or TT rider2? Does it power up when connected to the mains charger? Does it switch on when connected to the bike cradle? Check the fuse in the car charger.
My Tomtom rider 2 will not switch on. Battery has been on charge. Appears dead any solutions please?
Cy
Posted on Sep 06, 2010
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Posted on Sep 05, 2010
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
TomTom won't turn on
Try holding the power button in for about 15 - 20 seconds to see if it comes on, do this whilst plugged into a computer or your car.
Aug 14, 2009 | Tomtom XL 330 Car GPS Receiver
Is there a fuse or some sort of electrical protection inside a Tomtom rider bike dock that the user can change?
It is my understanding that a fine layer of corrosion can form over the contacts on the mounting dock and/or the TomTom itself after a period of outdoor exposure. A white course rubber eraser is the perfect instrument to remove that corrosion without excessive wear to the contacts. This is an old computer repair trick that I used on various computer cards. This is just an inexpensive trick to try. Hope it helps.
Jun 19, 2009 | Tomtom Rider 2 Europe Motorbike GPS 3.5"...
Tomtom rider will only switch on whilst under mains power and on
If it will switch on when connected to mains or car charger then perhaps your battery has had it. My battery no longer retains charge even when not in use. Suggest try new battery.
Feb 10, 2009 | Tomtom RIDER GPS Devices
Tomtom rider1 connection problems
Put two pieces of tape on the bit of the unit that slides onto the bike mount thus bringing the unit closer to the pins. Worked for me.
Mike
Jan 01, 2009 | Tomtom RIDER 2nd Edition GPS
Tomtom RIDER GPS Devices Logo
1,312 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
