Question about Linksys WRT160N Wireless Router
I can access the internet from my Apple MacBook Pro through my Linksys wireless router WRT160N. My printer is cabled to the router (ethernet), but I cannot print from my laptop. The cable is fine because if I shut off the wireless on my laptop and connect via ethernet (same cable) to the router, I can access the internet. So, what do I need to do to be able to print to my Canon ImageClass NF 6540?
  • 130 Answers
Try "Softperfect Network scan" Scan your network I.e. "192.168.1.100 - 192.168.1.255" till you find your printer.
good luck.
-Tom.
Posted on Jul 14, 2009
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Why wont my wireless internet connect to any of my devices ive tried resetting them and everything
- First of all can you connect to the router via cable (ethernet cable)!!!
- Access the interface of the router and try disabling the wireless security on the router and save it.. With the help of your device try searching for wireless networks and if you see the router connect to it.. then if its connect it should work but careful ( anyone can access your connection then ) if that work then see with the person you bought the router..
Apr 22, 2011 | Linksys WRT160N Wireless Router
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Samsung CLP-510 not printing
hi ,
i went through the website www.linksys.com and i found that Samsung CLP-510 is not compatible with wrt160n.
Oct 23, 2008 | Computers & Internet
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Internet connection problem.
If you have a macbook, it should have 802.11n, which gives you a 50ft range. Your linksys is probably the wireless G, which gives a 30ft range. Pull the power cable from the router and put it back in 5 secs later. Notice if you get flashing lights on the activity displat on the router. Linksys is the consumer side of Cisco. Ive seen those linksys routers blow in rainstorms. You may need to have to plug the computer to the router with an ethernet cable and reconfigure the wireless.
Let me know.....I can assist you in resetting the router.
Jul 08, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Linksys WRT160N Wireless Router  Logo
239 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
