Question about Garden
I have a honda mower and hit a big rock.
When i went to start it there was white smoke out the exhuast and oil dripping out the carb. after removing the head the valvees still seem to be fine the piston is good and the compression is at 60 lbs. it did manage to start up with a cloud of white smoke that swindled down to nearly anything before dieing
  • 154 Answers
The oil ring is shot, add some oil sealer to oil ,worked for me
Posted on Aug 05, 2009
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
1990 Honda cbr 600 f1 blowing white smoke but not the head gasket.
Is it really smoke? (oil problem) ... or might it be steam? (head gasket or other water jacket trouble) If it is smoke it will smell like smoke and linger in the air. This would also account for the dripping oil. Do a compression test to rule out rings. DOUBLE CHECK THE LUBRICANT YOU ARE USING ... USE ONLY THE GRADE AND WEIGHT RECOMMENDED BY Honda for your CBR 600.
Feb 17, 2014 | Motorcycles
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
I have honda accord 1993 SE.White smoke out of exhuast while i accelerate hard around 4 to 6 rpm.can any1 help me out.
White smoke is usually burnt water.
Check your radiator water level, if it is down, check for a blown head casket in your engine e.g.(water in the engine oil, or oil in the radiator water) brown froth on filler caps.
Dec 31, 2012 | 1993 Honda Accord
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
My lt1000 16.5hp b&s riding mower sarts great and runs for 30 sec then white smoke poors out the exhuast and dies.
It it is white/blue smoke it is oil getting into the cylinder. Check that the oil level is not to high. There are two other things to look at. The wear on the valve guides, oil could be sucked in there or the breather pipe, this will show up with oil on the intake to the carb, meaning a pressure build up in the crank case due to worn rings.
Feb 05, 2011 | Garden
Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Apr 11, 2009 | Garden
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
