Turn on your TV, VCR or Cable Box, depending on the
device you are programming.
Press TV* and release. Press and hold SETUP
until the One For All® Easy 3 Device's red
light blinks twice. Release SETUP
Note: When setting up your VCR and/or Cable Box,
substitute the appropriate device key (VCR or CBL
Enter the
first four-digit
code you wrote
down for the
device you are
setting up. (See
"Looking Up Your
Electronic Device
Code".) If you put
in the code
correctly, the red
light will blink
twice
OK.
11864, 10054, 10030, 10171, 10020, 10028, 10065, 10096, 11314, 11665, 11963
Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Ok.
