Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
D Link DIR-300 - Connection was Reset - Unable to set up router
D Link DIR-300.
The physical connections are set up however I am not able to enter the router set up by entering the Gateway 192.168.0.1.
Everytime I enter the gateway, it gives an error message "Connection Reset".
Could someone help me please, I have been trying to set up this router for the last 10 days now.
No one seems to know what to do?
Please help!
    President:
  • 1,383 Answers
Press reset button for 10 seconds then all settings are defaults.
you can access your router witrh following link
http://192.168.0.1 or
http://192.168.1.1
Posted on Jul 14, 2009
How to setup a DIR505 as a repeater in home. BSNL broad connection with modem modelDNA-A211.1. I am unable to setup
Yes here is your answer.
First setup for your modem. Click on this link and see detail. If you want zoom step photos in this help link page click on that photo which you want to zoom in.
BSNL Broadband Solutions
Secondly your router configuration, this settings are common for all compatible routers, so please refer your router's user manual for enter these values / settings.
Below I give you that your internet router settings help page link and router's user manual link.
Broadband setting help: Dheeru24k Pvt Sys Admin
Router's User manual: http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20505/Manual/DIR_505_Manual_US.pdf
Jan 02, 2014 | D-Link DIR-505 Wireless All-in-one Mobile...
D-Link problems
open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway, it should be your IP address.
If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping 192.168.0.1', hit Enter. If your PC is receiving connection from your router device, you will see a message like Reply from 192.168.0.1: bytes etc. If there is no connection, you may see the Request timed out message.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at here
Jan 23, 2013 | D-Link DIR-628 Wireless Router
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
Hi i have a problem with my d-link dir300 router.i wanted to reset it and now i can`t set up it anymore i mean when i try to enter on settigns page (192.168.0.1). please help me thanks
I am not sure what you need exactly but the following is a link for the D-Link Dir 300 Manual and you should be able to find answers to most questions in relation to this model
ftp://ftp.dlink.co.uk/dir_products/dir-300/dir-300_manual_v1.01_rev_A1.pdf
on a side note the adress to access most routers is 192.168.1.1. Hope it helps
May 24, 2011 | D-Link DIR-300 Wireless Router
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
Wireless connection stopped
try unplugging the connection for the modem and router each for 30 seconds, then plug them each back in again.
Mar 27, 2010 | D-Link DIR-300 Wireless Router
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
2,953 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
