Question about Samsung WF203ANW Front Load Washer
Door to my sumsung j845 will not unlock
The door to my j845 washing machine will not open it remains locked, have repeated the cycle a number of times and waited the 3 minutes. Can you help to slove this problem
I have the same symptoms, then i had a tech visit who replaced the internal door mechanisms which look like they were burn out.
After tech replaced the door mechanism, i still have the same symptoms. But after waiting 3mins after the cycle completion, i will turn off the machine which allows me to open the machine. It is not an omptimum solution but it works and saves me $700AUS buying a new machine. Hope this helps anyone. RB
Posted on Sep 03, 2009
I have the same problem and i rang samsung and they told me how to reprogram the machine. They told me to turn it off at the power point for 45 minutes, then plug it back in and turn the power on (not the machine)  and leave it for 15 minutes, then turn the machine on and hopefully it will unlock within 5 minutes. I had no luck with this so am getting someone out today.. hope you have better luck!
Posted on Aug 25, 2009
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
How do I get the door to open when still locked after normal cycle stopped with 1 minute left?
Try putting it through another cycle and see if it is still going to stay locked. That would seem like a timer problem. The door should only be locked normally, as I see it, when there is power applied to the locking solenoid so it should not remain locked with no power. You might call a maytag dealer and ask a sales or service person about this also.
Sep 08, 2014 | Maytag Washing Machines
How do I get the door to open on a Maytag washer that remains locked?
It sounds like the timer is defective. You may need to call a Maytag sales and/or service center and ask them what to do. WIll the washer start a new cycle?? If so start a new cycle and swee if the machine will get past this sticking point next time.
Sep 08, 2014 | Washing Machines
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit,...
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
500 series washer
Hey try this, open the doo rand oil the door lock mechanism. next turn the machine on and push start/pause button. repeat ,repeat, repeat. if it does not release open round acees door at the bottom of the washer,there should be a manual unloccking pull inside pulldown to unlock(very thin strip of plastic. repeat process. also make sure rubber gasket around tub is secure and flush around washer openig.
Aug 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Samsung WF203ANW Front Load Washer Logo
868 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
