Question about RTO 6391K Felker 24" Tile Master Plus Wet Tile Saw Kit
How to fix a tile saw pump - RTO 6391K Felker 24" Tile Master Plus Wet Tile Saw Kit
  • 4,340 Answers
Take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Posted on Oct 01, 2009
Where do I put the water in a wet tile saw?
read the directions usually in the bottom tank
Mar 06, 2015 | Saws
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Water feed problem, plenty of water from pump but line clogged,,,how to fix?
Blow it out with air or water or better yet, replace it. The hose is about 50 cents a foot at the big box store or your local hardware store.
Jul 24, 2011 | Dewalt 10 Inch Wet Cutting Tile Saw with...
Rigid wts2000l WEt saw is not sending water to blade even though it is in on position
look for weak pump, or blocked pump pick up.
I have a similar saw, and the pickup at the pump gets pretty grimey, and ned to blow it out once in a while to keep it clean and of cake like tile paste. also check the hoses for splits and/or cloggs.
Jan 07, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
The water doesn't seem to be pulling from our reserve to the hoses that lead to the tile and blade area...any thoughts?
i like to put my pump in a water bucket under the drain plug assembly,this keeps the pump\water cleaner from ceramic sludge,you might have to get a longer peice of hose,works great
Oct 11, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
Where to buy replacement pump STK#83200 for qep 24" bridge saw
Generally they're just a little pump for a fountain. You can pick them up at most lawn & garden stores for less than you can order the replacement pump.
Jul 01, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
MK water saw - water goes every where but on the blade!
When you say you turn the pressure up, I presume you mean you are opening the suction on the side of the pump.
On the saw which I have used in the past it is difficult to aim the warter spray. I opted for more water (open the suction on the pump) and let it go. most of it went onto the saw blade - some went onto the tile, some on me and some on the wall --- put a piece of cardboard or something behind your saw to help contain the overspray.
Sep 07, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
RTO 6391K Felker 24" Tile Master Plus Wet Tile Saw Kit Logo
910 people viewed this question
Top RTO Saws Experts
john h
David Hoff
Mike
Are you a RTO Saw Expert? Answer questions, earn points and help others
