Question about HP PSC 950 All-In-One InkJet Printer
My hp915 all-in-one scanner and copier not functioning, how can i fix this?
  • 36 Answers
First, uninstall the printer completely. Then download the latest drivers and software from HP here. Your printer is already selected. Also, go to the section labeled set up and install. This will get it working with windows at least. I'm assuming the printer itself isn't broken, but you would be able to tell. It wouldn't turn on or some variation of that.
Posted on Jul 14, 2009
How do I fix error code c-6740 on Konica Minolta c7000pro
C6704 Description Image input time out
Image data is not input from the scanner to the MFP board (MFPB). Remedy 1 Select [Service Mode] - [State Confirmation] - [Memory/HDD Adj.] - [Memory Bus Check] - [Scanner-Memory], and conduct the memory bus function. 2 Check the connectors between scanner section and MFPB for proper connection and correct as necessary. 3 Replace MFPB. 4 Replace CCDB.
Dec 09, 2014 | Konica Minolta bizhub Office Equipment &...
I cannot install my HP915 driver because i lost its cd
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=1153494&
Select your Operating system and it will give you drivers officially from HP You can select drivers,tools
If you want to re-order a cd you can do that on same page click CD-ROM Order page
However you can download drivers FREE
Jun 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
Need a services manual with codes and fixes
E000 : The main thernistor is opened.
E001 : Thermistor in short circuit.
E002 : SSR faulty
E003 :SSR and PCB faulty
E004: SSR in short circuit.
E005: Fixing web taken up.
E010: The main motor defected.
E012:Drum motor blocated.
E013:Wastw toner feedscrew faulty.
E014:Fixing motor defect.
E020:Hooper motor failure.
E032:PCB defect.
E061:Laser unit faulty.
E100 :The DC controller PCB malfunction.
E110:Laser scanner motor defect.
E121:M4 cooling fan defect.
E196: EEPROM faulty.
E202:Scanner home positin faulty.
E204:ADF controller faulty.
E220:Lamp inverter faulty.
E225:Xenon tube malfunction.
To reset in service mode press COPIER-FUNCTION-CLEAR-ERR.
Aug 11, 2009 | Canon imageRUNNER C6800 Copier
My hp915 all-in-one scanner & copier not functioning
Just select yes for the alignment and then place the paper upside down on the scanner portion and then press the scan button on the printer. Once this process is complete it will not ask you again to align the cartridge till you dont change it to new
Jul 18, 2009 | HP PSC 950 All-In-One InkJet Printer
Scan and copier not functioning
Reinstalling the driver Suite may help.
If not then scanner has short circuited, somehow.
Jul 14, 2009 | HP PSC 950 All-In-One InkJet Printer
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
HP 915 3-IN-ONE PRINTER, SCANNER COPIER MACHINE
Try downloading the software from HP.com:
Software and Drivers download page
Make sure to select the link to your operating system to get access to the correct software. Good luck.
Oct 17, 2008 | HP PSC 950 All-In-One InkJet Printer
Scanner error with no messages
Many problem of this printer caused by leaking ink,
look inside the printer using flashlight, at left side / ink cart. parking position,
ussually, there is ink drops to mainboard, this can affect one or all of it's function.
To fix it, you need to unpacking, and clean the mainboard.
May this help.
Jul 29, 2008 | HP DeskJet F380 All-In-One Printer
HP PSC 950 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
