Problem for Ovens
Generic problem for all Ovens
Vulcan oven will not stay lit
have an old commercial stove/oven/griddle combo, purchased second hand. everything works, but when I lit the oven pilot I was able light the oven, everything looked operational for a few minutes. After shutting the gas off I had to relight everything and again the pilot lit, then the oven. I set the oven for 400 and put an oven thermometer on the rack. The burner turned off and I am unable to get it to relight. Pilot is still on but looks very small. I can push the red button on the gas valve in and the pilot is normal momentarily. No joy on lighting the burner again.
any thoughts are appreciated in advance
Comments:
Nov 20, 2007
- cleaned the pilot and the oven has worked well today. Hopefully this will do the trick. Will monitor a couple more days. Thanks very much for the insight!
Nov 25, 2007
- seems to have done the trick!Dec 13, 2007
- well, kinda back to square one. Issue is now the pilot will not stay lit. If I relight the pilot and hold the button in on the gas valve the oven will light. I am suspecting the gas valve by now. Is there a part# for the valve and a separate one for the pilot circuit?
again, my thanx in advance.
Best Solution
posted on Nov 17, 2007
Rank: Guru
Expert
Rating: 86%, 613 votes
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Comments:
Dec 13, 2007
- If the pilot wont stay lit the thermocouple is most likley bad.make sure all the wire connections on the gas valve are clean and tight.call your local hobart branch and ask for the parts dept,tell them you need a thermocouple for your fryer,give them the model #.
Popular Solutions for Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range -...
1 Solution
Whirlpool 30" Self-Cleaning Freestanding Electric Range -...
3 Solutions
Kenmore 30464 / 30465 / 30469 Gas Single Oven
2 Solutions
Electrolux EOU6330 Electric Double Oven
1 Solution
Questions and Unsolved Problems for Ovens
90cm built in double oven
must have:
fan oven
auto timer
grill
available in UK
UK...
(More)
must have:
fan oven
auto timer
grill
available in UK
UK electrical spec
fan oven wont work convection works
What causes my pots and pans to turn black on the botom when cooking on a gas stove? Many thanks
after cleaning my oven and letting it cool it still won't open
