Question about KitchenAid Dishwashers
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
I have a Kitchenaid Whisper Quiet Plus dishwasher that is about three years old. About a month ago it has started making a loud humming noise like a bearing or pump is going bad or is restricted. Does anyone know what would cause this? I took the base plate off and the noise seems to be coming from the motor/pump that is centered on the bottom of the dishwasher.
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Posted on Apr 08, 2012
Same here. What gives?
Posted on Apr 30, 2010
So did ours, after 3 yrs, just started doing this too. Any luck?
Posted on Feb 25, 2010
My kitchenaid whisper has just started doing the same thing: have you made any progress on the diagnosis?
Posted on Feb 14, 2010
KitchenAid Whisper Quiet Plus dishwasher Location of serial number
Usually, the sticker is located on the inside edge of the door on either the left or right side--you have to open the door to see it.
Aug 19, 2015 | KitchenAid Dishwashers
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Broken part, need model number
I found a website called Partselect.com and they have very good pictures of exactly the part I need. I ordered it from there.
Jan 01, 2010 | KitchenAid KUDP01DLBL Split-Control...
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
My Energy Star/Built-in
Me to....My dishwasher is about 7 months old. It use to be extremely quiet. Now it is LOUD. but still works fine. HELP!
Oct 18, 2007 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwashers Logo
2,559 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
