Question about GE Energy Star WCVH6260F Front Load Washer
The spin cycle spins very slowly and the clothes come out extremely wet (drippping wet). How do I troubleshoot this problem?
  • 3 Answers
Our front loading GE washer did the exact same thing. It took forever for a cycle to finish and the clothes would be sopping wet. The problem was a clogged up drain filter. There were coins and a couple bills and some odds and ends caught up in there that was preventing the water from draining out. The spin cycle can't get going full speed until some of the water has drained.
I'm not an "appliance expert", but I have checked and cleared the drain filter a few times on my machine. I'm not familiar with your exact washer. Here's how I did mine:
Take off the bottom panel by removing the small screws at the top of the panel. Look for the white, round, plastic piece toward the bottom, facing you. Put a basin underneath it to catch any water, then slowly unscrew the filter. (if your basin fills up too fast just screw the filter back in and dump the basin, then repeat). Once you have it off you'll be able to immediately see any debris in there. Put the filter back in and the panel back on.
Posted on Aug 06, 2009
  • 583 Answers
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jul 14, 2009
  • 3 Answers
We had the exact same problem with our washer, and we just fixed it because of the valuable input here at Fixya. It wouldn't drain or spin. We took off the front panel and removed the drain filter. It was full of handfuls of dog hair, two lollipop sticks, one pen , four paper clips, and $2.99 in change. Thanks everyone for your help!
Posted on Oct 12, 2009
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Not spin drying the clothes
check to make sure the pump is not restricted or drain hose kinked.
May 20, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Only spins slow
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 06, 2009 | Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Spin cycle is slow, cloths still extremely wet after spinning
problems with spin cycle could be due to variable reasons.components involved are the lid switch, timer control and the motor.The clothes might be soaked because there could be a drain problem.check whether the drain is clear for partial blockage.also inspect the water pump.
Dec 13, 2008 | GE WWSE5240G
GE Energy Star WCVH6260F Front Load Washer Logo
873 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
