Question about Rancilio Silvia Espresso Machine
Boiler light never goes off
My son was showing off for a girl and tried to make her a Latte from my Silvia (ignoring my request to keep his hands off). Long story short, he left the steam switch on and walked away. I found Silvia dead the next day. I have reset protection and replaced both thermostats, but the boiler ready light does not go off. I'm guessing my heater element has been damaged and therefore not getting hot enough to trigger the thermostats. I do get hot water and some steam, but Silvia is not working right. What else might be the problem,or do I have my son buy me a new machine? Is there a test I can do on the heater element, i.e. Ohm meter? Can I buy a replacement element? Thanks!
  • 1,089 Answers
Hi
If you have an ohms meter, do a check of the element in the boiler. The reading should be between 12 and 16 ohms. If you don't have any reading, you have a bad element and need to replace the boiler.
Posted on Jul 14, 2009
My silvia is less than 2 years old. Yesterday I let the steam switch on and forgot to turn it off after steaming. It was on for about two hours. Then it won't heat up either. Should I get new part
On the happy side, if you tried to re-heat the boiler and found this problem straight after it failed, the thermostat may still re-set once the unit cooled down. So leave it a day and try again. Alternatively, it could be a burnt out fuse or on the less happy side, a burnt out boiler.
If no lights come on its a failed fuse. But if everything else is normal but it still wont heat, the best option is to take it for a service to a qualified technician as it may be that the boiler was damaged.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
Is there a repair manual for the rancillio silvia
There is not a repair manual for the silvia, the most that can go wrong is the 3 resettable thermostat on the top of the boiler, remove the 4 screws on top of the machine for access. Unless you run the boiler dry. Then if the thermostats did not kick off in time then you will need a new boiler. You will notice a discoloration in the water out of the group or the steam valve.
Jan 03, 2011 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
The boiler doesn't heat up--no hot water
Hi
Contact fixya because they won't let me tell you. They say its to long.
Dec 09, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Rancillio Silvia Steaming problem
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Aug 02, 2006 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
258 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
