Question about Vornado 283HD Box Fan
Blades stopped turning. - Vornado 283HD Box Fan
    Problem Solver:
  • 6 Answers
Your fan motor is most likely burnt out.
Posted on Jul 14, 2009
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
What would cause the PTO not to disengaged the blades from turning?
A faulty switch if the blades are spinning at full cutting speed
Not cutting the current to the engaged blade clutch so the blades are stil on even when the switch is in the off position.
The blade brakes not gripping the pulleys fully to stop blades so anything brushing against the blade will start them spinning
Or the clutch medium is damaged and is not releasing the blades fully so they spin but slowly when you switch the switch they just slow down get the deck alignment switch for clutch and the wireing to the blades system checked and the braking system for the blades pulleys checked as soon as possible the machine is dangerous
With the blade continuously rotating you risk injury from the blades catching.g you or someone else who's not aware the blades don't stop.etcetera.
Jun 09, 2014 | Toro Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
My LT 1000 was working fine, and then the blades stopped going. When I backed up and waited a minute - the blades began turning again. Everytime that I hit some higher grass, the blades stopped again. ...
Hi. It sounds to me like the belt that drives the blades are worn. Take note of the routing of the belt, or take a snapshot with a camera, and remove the belt for a sample at your spares shop. Hope this helps
Jul 09, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
04 dodge ram 1500 wiper arm goes down before going up
remove wiper arms at the shaft, right at the cowl. each will have a nut on them but it is covered by a piece of plastic that will snap up for access. take nuts off and remove wiper assembly. turn key on turn wipers on make sure shafts turn when on, then turn off the shafts to stop in park position. then reinstall wiper assemblies in their park position .
Dec 28, 2008 | 2004 Dodge Ram 1500
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Vornado 283HD Box Fan Logo
160 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Mack Baxter
Jerry Kramer
Jerry Kramer
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
