Question about Boating
Will not turn over on my kawasaki js 440
My jet ski is making a clicking noise when i try and turn it overbut not cranking the crank shaft, i had it turning over and then it just slowed down and now it doesnt do it at all anymore. does anyone know what this problem may be
    President:
  • 1,273 Answers
It sounds like you have a nearly dead battery. Try charging it with a battery charger, and have it tested after charging at an auto supply store.
Best regards, --W/D--
Posted on Jul 14, 2009
The ski has good compression and spark but after it starts it diers shortly after and the carb fills with fuel and floods it and then it doesnt start untill it dries out do you know what could be yhe...
Your carburator bowl float is stuck in open position, or it is sticking allowing the gas to flood the engine.
Remove the carburator boal and try to clean or replace the carburator bowl float.
Jun 24, 2014 | WSM 1977-1986 Kawasaki Js 440 Cc Jet Ski...
I got a 1990 kawi js 440 andf rebuilt the carbs and its hard to start and when it does it dies then the carb floods with gas and will not start again cuz of to much fuel do you know what is wrong
Js 440 jet ski has no spark
check plugs are good , is there a spark at both plugs and make sure both are to earth as they spark at the same time known as a waisted spark coil ? remove plugs from caps and put a metal rod of some sort in them and hold against your hand and crank engine and you will feel a slight voltage if working ! wont hurt you !! if no remove caps and repete ! if no check kill switch isnt stuck or corroded etc ! P...
Dec 02, 2013 | Encore Software Kawasaki Jet Ski...
I have an kawaski 440 jet ski and how much oil does it take in the gear box and what kind
Your 440 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Apr 16, 2011 | kawasaki Full Suspension Mountain Bike Men
How do you time a js 440
remove gas tank and flywheel cover, then remove flywheel with a 3 finger puller, timing mark is located on stator plate and if memory serves the align mark on the plate is to match the seam on cases. But your going to want to crank that stator counter clockwise almost as far as it can go for better performance.
Jun 29, 2010 | Encore Software Kawasaki Jet Ski...
Electric Starter Sticking I have a 2000 Kawasaki Ultra 150. I just changed that battery and was going to make sure that it started before tomorrow. When I first pushed the start button, it didn't do...
Sounds like a stuck starter solenoid,if you can get to the solenoid tap it with the handle of a screw driver,might take a sharp rap if it quits cranking then you will need to replace it...
May 27, 2010 | 2000 kawasaki VN 800 Vulcan Classic
I have a 1989 kawasaki js 550 jet ski. The engine turns over but I do not get spark out of either spark plug? what is the issue and how do I trace the electrical problem?
Check the ignition coils to begin with and basically follow the wiring back to the stator making sure you have proper voltage at each component, also check to make sure everything is grounded properly, it is very common for the grounds to be corroded on marine equipment. I will have to check but I am sure I have a dealer service/ troubleshooting manual for kawasaki skis, so if you have any other questions about yours let me know.
Nov 19, 2009 | 1989 kawasaki GTR 1000
2002 polaris jet ski. Cranked 1 month ago with no
you need to put a new battery in it if that does not fix it you will have to replace the solenoid
Jul 08, 2009 | Boating
Boating Logo
243 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
