Question about Magellan Maestro 3250 GPS
Map is stuck on an old location and won't change to the new location on the map
    President:
  • 1,111 Answers
Take the unit outside so that it has a clear view to the open sky, turn the unit on, then push the reset onthe side(you need a paper clip) youll know its reset once you see the magellan logo screen with the black loading bar on the bottom. let in sit outside to Aguire the satellites. this may take upto 30 minutes. if that does not work, you can try the latest update. bill
Posted on Jul 14, 2009
Where is the Map Sensor on 2005 Ford Escape 4Cyl ? How do you replace it
M.A.P. Sensor Operation: Measures intake manifold vacuum pressure to help control the air and fuel mixture and timing. Contains a pressure-sensitive element that connects to an electronic circuit, generating a signal that changes with pressure changes in the manifold.,all you do is unplug ,old one and remove the screws or small bolts and replace and plug in new one ,be sure to clear computer before running. if this helped please let me know .
Woody
Sep 10, 2014 | 2005 Ford Escape
Gps wont accept the change of maps stuck on the select map screen
reset the GPS there should be a pin size hole on the side find it and reset it. You need to program it as well to your exact location.
Oct 23, 2013 | ACR Maylong Group FD-220 Car GPS Receiver
Turn signal won't work - changed bulbs and can't find were the flashers is
check the fuses located in passenger floorspace near center console. fuse cover panel should map out what fuse is what and you can test it once you find it y replacing it with a like-voltage or new fuse
May 06, 2011 | 2000 Jeep Cherokee
Need piture for 1995 buick rivera supercharger of were the map sensor is at
MAP SENSOR ON TOP OF INTAKE BESIDE THE SUPERCHARGER. TAKE THE NEW MAP SENSOR USE IT FOR REFERENCE LOCATING OLD MAP SENSOR. WHEN YOU SEE IT ON INTAKE IF MATCH UP WITH OLD MAP SENSOR THEY MATCH UP YOU LOCATED THAT IT.
Sep 14, 2010 | 1995 Buick Riviera
How hard is it for a shadetree mechanic to replace the manifold absolute pressure sensor on a 2000 4-cylinder Olds Alero? When I bought the part, it says it is an EGR vavle and I remember replacing those...
The EGR valve and MAP sensor are indeed different and unrelated parts. An EGR valve that is stuck open can however cause the system to set a false MAP sensor code due to the loss of vacuum in the intake which will cause the sensor to read low but the engine should run very bad, if at all, when this happens. The MAP sensor is located slightly to the drivers side of the throttle body housing on the front side of the motor and is easy to replace. I'd make sure that your EGR valve isn't stuck open or that you don't have another large vacuum leak that could mimic a faulty MAP sensor before replacing it however. Hope this helps a bit and good luck!
Jul 20, 2010 | 2000 Oldsmobile Alero
Gps won,t move from last location
When you put in a new location how are you entering it? If you are using the "Where to?" menu then you will need to click on the "Map" button instead of GO when you find the point you are looking for, may it be an address or a Point of Interest. This will show the location on the map. If you want that to be your current location you must have the GPS turned off. Then on some units you will Have the option to set as your current location.
I hope this was some help.
Cheers
Jul 14, 2010 | Garmin StreetPilot C330 GPS Receiver
File format error
search on the internet for other file, because yours is broken. After you have it, overwrite the old file.
You can try http://rapidlibrary.com/index.php?q=canada+fbl+maps
Apr 08, 2009 | Mitac Mio P550 GPS Receiver
Garmin 360 keypad stuck
operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
Aug 20, 2008 | Garmin nuvi 350 GPS Receiver
Change Home Location on Nuvi 660
Go into 'Where To', 'Favorites', 'HOME', 'Edit...', 'Delete'. Then from the main map screen you can tap the screen and 'Save' the location as your new home. You can't save a 'Home' location if there's already one called that in memory, so you have to delete the old one first.
(I have a 680, but I assume it's the same)
Oct 16, 2007 | Garmin Nuvi 660 GPS Receiver
Magellan Maestro 3250 GPS Logo
333 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
