Question about Exercise & Fitness
I have a Sears Pro Form 730si. The treadmill
I have a Sears Pro Form 730si. The treadmill goes for a few seconds and stops. An error message E4 appears in the speed indicator box. What is the problem with the treadmill?
  • Anonymous Mar 16, 2014
    Magnet won't start my Pro-Form Crosswalk 400e Treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
  • nelson7701 Dec 03, 2010
    You need to clean and lubricate the treadmill belt. You can get the kit to do this from Sears Parts Direct.
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
Mar 23, 2013 | Lime Pro Lime Mt9 Treadmill Exercise...
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
A friend of mine gave me her old Sears Pro Form Space Save 730 SI Treadmill..I was able to use it twice and for some reason I cannot start it...It lights up but does not move...I do not have a Manual..Is...
hi,
I have the manual of Pro Form 730si . If you can give your email as a replay for this then i will sent the manual to your email id. I can't upload the manual through fixya. Because its a pdf file.
OK
Sep 18, 2011 | Proform Exercise & Fitness
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
E2, E3, E4 CODES ON A SEARS LIFESTYLER EXPOSURE 1500 MACHINE STARTS OK BUT SHUTS DOWN W/ E CODES AFTER A FEW MINUTES.
an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
Jan 07, 2010 | Exercise & Fitness
Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Aug 29, 2009 | Nautilus Tr300 Treadmill
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,402 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
