Question about Fisher Paykel EcoSmart GWL15
The washing machine doesn't come on when switched on at power point. No lights or sound at all. The fuse to the power point is all good. Machine was working fine the last wash load. Tashina
  • 583 Answers
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
check out this.
Posted on Jul 14, 2009
Washing Machine will not start
either your door actuator is broken or the door switch itself. look at the door and see if the latch(actuator) is broken or loose. If not order a door switch. It can be changed easy if you remove the retainer from the bellows and loosen it from the front of machine.
Hope that helps
Nov 26, 2013 | Washing Machines
Machine won't start, lights are all on and ready to wash
No power
Lid switch
Goodluck.
Jun 06, 2008 | LG WM-1832C Front Load Washer
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
I have a key came on my washing machine will not which on
see the causes, and fix it.
1) use the key and see if the key is o.k , test the recipint may be is defective, this is a electrical switch.
2)If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. 9_23_2012_4_33_11_am.jpgsee your wiring diagram behind the machine. or you must open the covert from the control and your will see it.
Sep 22, 2012 | Bosch Washing Machines
Washing machine water
Firstly, do you have water at the moment? Then, your power must be on and the taps turned to on - hot, cold or both.
Secondly, the cycle must be selected and activated; by pulling or pushing the control knob.
Still not working? Check power to the house. Switch on a house light. Does it work? Plug something else into the power point. Does this work. If not, then the fuse may be blown. ELCB (safety switch) may have tripped. Reset, replace etc;
Lights on but nothing working - then switch off, unplug the machine, turn off the taps and disconnect the hoses to the machine. Most washing machines have inline water filters and these can become blocked. Clean/replace and try again.
Beyond this it may be that the solenoids are broken and need replacing. A multimeter could confirm this.
Sep 21, 2012 | LG Washing Machines
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
Washer does not start, replaced lid switch, and timer still doesn't work. when parts mentioned were replace. washer did start and fill but then stopped.
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Sep 24, 2011 | Maytag Washing Machines
Thers no power to my washing machine.changed the fuse and theresstill no power.what do i do ? thank you emma
Hi emma... Unplug the machine from it's current outlet and use a heavy duty extension cord to plug it into another outlet that you know works [plug a blow dryer in to check it].
If the washing machine works then you know the problem is in the outlet or the wiring to the outlet. IF the washing machine still doesn't work you know the problem is within the washing machine itself. Possibly the lid switch or a fuse within the machine. J.
Aug 02, 2011 | Indesit Washing Machines
No power,not lighting up when start button pushed. unplugged and replugged several times. no good
is machine lighting up when power point is turned on ?if it isnt then control module is faulty. if it is and your power or start button dont work could b faulty keypad or faulty lid switch.please reply if u need more help
Mar 07, 2010 | Fisher and Paykel IWL12 Top Load Washer
Creda 120vw washing machine fuse changed still no life
You start looking from the power plug, down to the power-cord. The power point in the wall, (plug in something else to check power), the pause switch on the machine, any lights on the machine? Did you open the door to get the clothes out?..........
Careful when the power is on & the top off.........
Dec 22, 2007 | Creda W100FW Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
349 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
