Question about Mitsubishi CS-27205 TV
Widescreen Black Diamond CRT TV 32inch
Screen has shrunk gone black from both sides leaving about 14inch screen in middle. What should i do .
4 Suggested Answers
  • 1284 Answers
SOURCE: mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Posted on Apr 07, 2007
  • 133 Answers
SOURCE: black box in middle of screen
If you have a menu button on the front of your tv go into the closed caption portion and turn off the text mode . This will get your picture back . If you don't have a menu button on the front of your tv you will need a remote that can access the menu . Good luck
Posted on Feb 29, 2008
SOURCE: a black square takes up 90% of the screen
You need to turn off the TEXT Captioning. I had the same problem and that fixed it.
Posted on Jan 09, 2010
  • 2098 Answers
SOURCE: mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Posted on Jan 14, 2011
0 characters
1 Points
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Standard (CRT) Televisions
Av-32f476 picture shrinkage
I had a Crummy Westinghouse TV that had a problem like this. JVC's are typically better built then a Westinghouse. My first educated guess - sounds like it's a voltage issue, most likely on the high voltage. Probably a capacitor on the power supply side of the motherboard or the capacitor in the flyback transformer. Just and educated guess.
Jun 23, 2008 | JVC AV32F476 32" TV
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
Screen 1/2 black with random caption in middle side
Aug 16, 2007 | Sanyo DS24205 24" TV
Mitsubishi black diamond tv
Apr 07, 2007 | Mitsubishi VS-1250 TV
Black comes across right side of screen
Sounds like you've got whats called a cold solder connection somewhere in the horizontal width control circuit or a connection in the sweep section. Should'nt be two expensive but unless you have had some soldering and troubleshooting experience I would leave this on to the pros. Good Luck
Jun 02, 2006 | JVC AV-36D502 36" TV
Tv picture
sounds like it could be a problem in the vertical sweep curcuit as if the vert sweep fails it blanks out the video and screen drive so the tubs dont get a line burnt into the face of the picture tube. Have this checked out by a pro as I doubt if you can do this repair unless your an electronic tech.. Good Luck
May 19, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standard (CRT) Televisions Logo
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
