Question about Mitsubishi Televison & Video
I have a mitsubishi model number vs60803, when i turn it on the picture is fine, but after a few mintues of watching tv. the screen spits into 2 clors, blue and red almost like 3-D
    President:
  • Mitsubishi Master
  • 1,779 Answers
It's possible you have cold solder joints on the Convergence IC's. There are two of them in your set. They will be mounted on large finned heat sinks. It will require soldering.
Posted on Jul 14, 2009
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and covette54@live.com
Feb 23, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Looses video
There are so many thing that can cause this to happen. If you answer some questions we can narrow it down some. 1) when the picture goes black if you hit the menu button on the mitsubishi remote or on the front of the tv itself does the menu show up? 2) After it goes dark how do you get it back? do you turn it off and let it sit for awhile or can you turn it off and then right back on to get a picture? 3) what is the model number? this can be found on the back of the set. If you can answer these questions we can go forward.
Thanks!
Tim Nolan
Sep 11, 2008 | Mitsubishi WS-55807 TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Projection TV No Picture No Sound
Hi Chelon alot of Mitsubishi tv's around the time the model number you are stating where built have a small PCB on the yoke of the picture tubes, connections on these boards (one of them) break down so the set loses one of the scaning circuits (vertical or horiz) the circuitry senses this failure and shuts off the picture (some models the whole set) this is to protect the picture tubes, try wigglin the heavy cable going to each of the 3 tubes (unpluged from wall socket) then plug it in and turn it on. Once the set is up, carfully wiggle each of the cables goin to the yokes until the screen flickers or flashes now you know which one is bad repair it is a bit of task but lets see it you get this far first.
May 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv repair
try resoldering the vertical output IC and the horizontal output transistor. It sounds solder related
Mar 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Mitsubishi VS50607 Self Diagnosis 2-3
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 21, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Red Lamp
How much does the lamp light cost. Where do we purchase this??????
Oct 15, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
