Question about Panasonic CT-32G33 TV
Panasonic television 2001 model picture goes out/ sound stays on
Panasonic television 2001 model with built in dvd- picture turns on and off but sound works continuosly. tapping the tv usually brings the picture back. Any ideas? Thanks
techman
  • 3130 Answers
SOURCE: Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Posted on Sep 15, 2006
  • 236 Answers
SOURCE: Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Posted on Apr 23, 2007
  • 81 Answers
SOURCE: Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
Posted on Jun 11, 2007
  • 298 Answers
SOURCE: Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Posted on Nov 29, 2007
jerryg50
  • 1667 Answers
SOURCE: Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Posted on Apr 26, 2009
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Picture goes of and on with HDMI1 on screen sounds stays on
This sounds like the signel board is going out in the HDMI jack and needs replaced! Also try another jack to make sure its not the cable!
Please rate my response!
Rhank You!
Jan 15, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Memorex 32'' LCD TV/DVD combo, DVD will not play
funny how **** happens....mine turns on and says memorex then stays on with no picture or sound.
Aug 10, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Jan 12, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Black screen
May 12, 2007 | Panasonic CT-32G34 34" TV
Panasonic CT-32G33 TV Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
