Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Intermittent low to medium power output from radio, any ideas
  • 64 Answers
The problem is not your radio.One of your connectors -pl259- is dis-solder or open.Could also be a loose antenna connection or an open coax that when you move it,makes contact.
Posted on Feb 15, 2010
Cluster panel lights on 2005 ford freestar goes off and comes back on no problem with engine etc why
Pull the fuse and put it back in, first. Then pull the plug on the back of the IP and put it back in. It is intermittent. These will usually fix the problem... Corrosion.
Jul 01, 2016 | 2005 Ford Freestar
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
I need help asap 2003 Expedition code p0171 and code p0712 i have and idea of the 1st code but whats the secound code i really need help i dont want to take it to a shop where there going to charge me alot...
P0700 Transmission Control System
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System -Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Pedal Position Switch -Circuit Malfunction
P0705 Transmission Range Sensor/Switch Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor/Switch Circuit Range/Performance
P0707 Transmission Range Sensor/Switch Circuit Low Input
P0708 Transmission Range Sensor/Switch Circuit High Input
P0709 Transmission Range Sensor/Switch Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine RPM Input Circuit
P0726 Engine RPM Input Circuit Range/Performance
P0727 Engine RPM Input Circuit No Signal
P0728 Engine RPM Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit
P0741 Torque Converter Clutch Solenoid Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
Now i dont know a lot about automatics especially modern ones with all this fancy electronics thats used nowdays but i think its a fault with the temperature sensor for the gearbox.But where its located and what it looks like i have no idea it could even be mounted inside the gearbox .Sorry not a very good answer from a mechanic but?? very few of our europeon cars come with auto transmission .Evan when i do know whats wrong i cannot buy the parts for the gearbox as only re-con boxes supplied by the dealer so best advice is to try a specialist in auto box repairs only .PS some of my best students when i used to teach mechanics many moons ago were the girls so no excuses like iam only a girl please
Apr 22, 2013 | Cars & Trucks
The outputs on my Pioneer GM-5300T are intermittent and low
yes they are perfect whenever I turn up the bass it just trips on and off
Feb 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
BMW E39 Radio Interference on Medium wave
This is a signal strength issue.
Jun 28, 2017 | Car Audio & Video
Replacing the wiper control unit on a 1999 honda accord
yes it will get worse-yes they can stop working all together-you must replace the arm on which the switch is attached connected to steering column- get a used one from junk yard and a book at library
Nov 14, 2008 | 1999 Honda Accord
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
108 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
