Water run and stop,when start over same thing happen,stop with a error message.
  • manikandan murthy
    manikandan murthy May 11, 2010
    can u be more specific what error message it shows?
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
My Bosch washing machine pumps the water out continuously without ever filling the tub. When I first start a load, the water moves through the detergent dispenser but never gets to the tub. About 5 minutes...
Could be time to call the electrician. If the freeze happened recently you are possibly further inland than me. Lagging on pipes often helps and wrapping external taps and pipes with towels or the likes for winter and with plastic tied over top if in the weather. After super cold frosts we are best not running showers and taps till midday or later occasionally. Vehicles can be similar if it is cold enough. Fill jugs and bottles the night before for breakfast if the water might freeze. If your water might be soon dirty because of a flood or water supply stopped, fill the bath with clean water before it is
Feb 28, 2014 | Washing Machines
ArcSoft Daemon Connect Stopped Working error message
It could be a virus, run anti virus to clean this up
Dec 17, 2011 | Dell Studio 15 Laptop
During every cycle, I get a "check water tap" message? It stops running and beeps until I press the start button again
Welcome to FixYa.
What happens when you press start again, does it continue on through the cycle or display error again ?
Typically this message indicates the water is shut "off", a hose is "kinked/pinched" or a small screens/strainers inside the fill hoses has become blocked or partially blocked.
If you turn off your water and remove the hoses from both ends, clean out the screens in the hoses and in the valve, that may remedy the issue.
Let me know what you find and we can go from there.
Good luck.
macmarkus :)
Aug 26, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
PI error messag every couple of hours
check the water level sensor's position. has it become loose from its mount and touching the water sooner then it should? it could be a probe or a float
Jul 27, 2009 | Danby DPAC8020 Air Conditioner
Err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Apr 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Ps print 08 error
Goto:
Start > Run > MSCONFIG > Startup
And look for an entry relating to that name, uncheck the box and restart.
Let us know
Good Luck
Mar 28, 2009 | Microsoft Windows XP Home Edition
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold ...my screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
