Simpson aquapulse 713 7kg heavy duty washing machine does not stop filling up.
  • marama63 Jul 14, 2009
    I hope your advice helps. I havent tried yet but will do so soon. thanks!
    President:
  • 2,187 Answers
Hi There,
There could be 2 components that cause this problem on your washer. One is the water fill valve and the other is the water level control. The water fill valve found at the end of the tubing for your hot or cold water if the one that lets the water in. It has an electrical component called a solenoid that tells the valve to open or close. You may want to check if the connections are loose or if there is no continuity in the solenoid then it may need replacing. Check the valve if it closes completely or not. It may be set to close but it has not closed completely letting some water in. Another is the water level control. An air tight hose is connected to the tub at the bottom towards the top part of the washer. At the hose's end at the opposite side of the tub us the water level control. Check if the hose is properly in place or the wiring on the water level control. Or the water level control may be faulty.
Posted on Jul 14, 2009
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Nov 12, 2016 | Simpson Washing Machines
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
The water is not draining out of the washing machine what could be wrong
not much info out there on this one
water pump solenoid or water pump
faulty control board timer
to empty machine run drain hose out the door
or towels and buckets
Sep 17, 2016 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Remove the clothes and check for free movement of the drum, if there is friction then check the motor and belt assembly, check the free movement of the bearings. Also make sure that the inlet water level is good and the water level set is correct for the clothes quantity. If not the clothes will be dry on top and might cause such an issue
Oct 03, 2013 | Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
My Simpson 806 Heavy duty washer fills then stops, flashes SF on screen and beeps. Anyone got a solution?
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
on certain models the "sf" stands for service filter.
Jan 12, 2012 | Washing Machines
Washing Machines Logo
200 people viewed this question
Top Washing Machines Experts
