Question about Ovens
I have a KitchenAid KGSA906 gas range. Display panel is blank and the door will not open. Outlet is energized. Any possible solutions other than unplug/reset or display replacement?
  • 35 Answers
If it has a control board it is bad needs replaced
Posted on Jul 15, 2009
Samsung gas range oven will not heat up
you may have a bad thermocouple this is the device that senses a pilot light and unless this device is satisified the main gas valve will not open it is a relatively inexpensive part but you indicated display is blank so the t/c
may NOT be the problem try to unplug the range for about a min and reconnect maybe the main power supply may have gotten zapped by a surge there may be a fuze for the power supply
Apr 09, 2012 | Samsung Ovens
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
We put our KitchenAid oven onto self cleaning mode, now the display is blank and the door will not unlock. It has been over 15 hours, and the oven is cool. How do we reset it?
Is this a built in wall oven or a freestanding oven/range combo?
If its a wall oven the problem is going to be a high limit thermostat that went out. If it is a older model the high limit t-stat has a red reset button that can be pushed and power will be restored to controls. If it is newer once the high limit goes out it needs to be replaced. Now heres the tricky part on wall ovens, the high limit thermostat is inside control panel and it needs to be taken apart to get to that t-stat and that can be a problem trying to get it pulled out enough to get to control panel with the door being able to open. On that i wish you luck
Thier is also a high limit on the freestanding range its going to behind the back panel and easier to get it since your not dealing with something built into a cabinet
Good Luck,
Gene
Aug 18, 2011 | KitchenAid Ovens
I used the self cleaning, quick cycle. When cleaning completed the display panel light went off and the door is still locked. Cooking part of the gas stove still works. Could you help us...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jan 05, 2011 | Ovens
My display reads F5:E7 on a Kitchenaid Superba stove. email cmaffey@hotmail.com
Well, its 10:30 on a Saturday night, and I was so frustrated by my Kitchenaid Oven. I set it to clean, but afterwards it would not unlock. the display read F5:E7, which i found out means the door unlocker won't work.
So, how did i fix it, well there are two ways, to get your oven door open.
I only found this out after tinkering for 2 hours, and found the easiest way to get your oven going again:
Pull your range out so you can see behind it. You will see a rod in the upper center part of the oven. There is a cutout in the metal and you can see the solenoid that locks the oven. It is connected to a rod. This rod is what goes to the front of the oven and is what is keeping your door locked. Simply move that rod the opposide direction, it will click, and presto, your door is now open.
I never bothered to replace the solenoid, because I didn't know if it was bad, or the controller board. The Solenoid itself is $90, I don't want to even guess what the control board is.
So, not technically a fix, but it will get your oven open. Just don't clean it automatically any more!
Sep 30, 2010 | KitchenAid Ovens
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
Ovens Logo
220 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
