MW511 washing machine continuously restarting washing cycle.
I have an issue with the washing machine continuously restarting the washing cycle after completion. After some research, it appears the recycle feature was on. After entering diagnostic mode and turning it off, I attempted a wash but it immediate restarted again after the first wash had completed.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 720 Answers
Isnt there an error code your not telling us about
Posted on Jan 21, 2018
SOURCE:
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Posted on May 11, 2008
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
  • 14 Answers
SOURCE: Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Posted on Jul 07, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
Fisher & Paykel MW511 washing machine.
Make sure pump activates in pump out cycle.And also check washer settings switch for irregularities.
Apr 14, 2018 | Fisher Washing Machines
Fisher pay kell mw511 . Keeps going through the cycles continuously. Won't stop after last spin ..?
Switch it off from the wall socket for a few minutes, then switch it back on , this will reset the computer program, and every thing should be back to normal .
Sep 03, 2016 | Fisher Washing Machines
Mw511 pride top loader shows lid locked and issues loud beeping.Is mid cycle and full of water
When it beeps what is the error code? Look at the top row of lights and count from left to right.Tell us which of the 8 lights are on & which are off.
May 29, 2016 | Fisher and Paykel Washing Machines
Mw511 fault code what does this mean?
This makes no sense, MW511 fault codes are in binary using the cycle LEDs. If you are referring to the lights that are on from diagnostics mode "2,3,4" would be 01110000 (112) or 00001110 (16) depending on which way you are looking at it. Neither of these codes exist. You would do well to explain what code you want, or how you are obtaining it.
May 21, 2014 | Washing Machines
Fisher and paykel mw511 washes but not spin and smell during this cycle
If it smells during the spin cycle the belt could be slipping and burning in the pulley. You may need to replace the belt.
Feb 08, 2011 | Washing Machines
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Open Questions:
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
