Question about Samsung TV Remote Control
Remote stops working does not respond all the time
Some times the cable button works and sometimes it does not.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Change the battery that should be the problem if the problem still persists then its hardware problem got to get a new remote.
Posted on Jul 14, 2009
My samsung LCD LA32R81BM remote control is not working at all. I have checked batteries and its terminals.
Posted on Aug 10, 2009
Menu button stopped responding
If only one button does not work at all or all do not work the unit may have a lock out feature that would be explained in the owners manual.
Apr 10, 2012 | Vizio Televison & Video
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
TV is not responding to the remote control.
The set may have defaulted to a front panel lockout. To defeat that on the front of the set hold down the MENU button for 15 seconds and see if it will then power up. I know that doesn't solve the problem with the remote but one step atta time. These sets are prone to leaky switches on the control panel and when that happens the micro cannot accept two different commands at the same time. That could be why the remote is not working.
Apr 05, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Dec 06, 2008 | 2000 Mazda MPV
Remote works intermittently
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Oct 09, 2008 | Kenwood VR-407 Receiver
Remote control "enter" will not respond in DVD mode
I had the same problem. Powering down and rebooting (unplugging) the recorder fixed the problem.
Mar 12, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Tv does nit respond to remote
The problem is inside the TV, caused by a cold soldering on the circuit board where the infrared receiver cables are connected. Needs to be resoldered.
Dec 16, 2007 | Zenith E44W46LCD 44" Rear Projection...
Samsung TV Remote Control Logo
433 people viewed this question
Henry  Thomas
Henry Thomas
