Question about RIM BlackBerry Pearl 8100
My blackberry knows the media card is there but I can't access anything synced to it. Already formatted it, and when I plug it in to the computer it reads the files as being on the phone. Why can't I access them from the blackberry?
  • 36 Answers
This has happened to me also, check to make sure the memory card size is supported by your phone. For example, I have an 8GB micro SD card. It will work in one blackberry, but my other one only supports up to 4GB. You would have to check the instruction manual.
Posted on Jul 14, 2009
My bb 8520 says media card cannot be read. verify that the memory card is formatted. what do me?
The best thing you can try to do is connect the media card to your computer. When you see it show up in "my computer" or "computer" right click on it, and select "format". Make sure the formatting is in either FAT or FAT32. Once that is done, put it back in the phone and try again. If you cannot plug the card into the computer, then use the supplied USB cable for the phone, and plug that in to the computer. On your screen it will ask if you want to sync, enable mass storage or charge only, make sure you select enable mass storage. If you do this your card should be readable on the computer and then you can format it using the same method I described. Just note that if your blackberry gets plugged in, it will show up with 2 "storage cards". One of them is the memory that is on the phone and the other is the actual media card. Make sure it is the media card that you have selected to format.
Sep 13, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry bold 9650 is reading my scandisk 8 gb media card as a 4 gb media card. This just started happening. I found the problem when syncing my music. All of my music on Itunes used to fit on the...
joel paterso,
I will list a couple of suggestions that you may already know about, but hey anything is better than nothing, you'll go away knowing you tried everything.
1. It could be that the memory card is now corrupted, in this case there is no hope just buy a new on from ebay, thay are alot cheaper there if u can wait a week or so.
2. It could be that the software is only recognizing "free space" so don't worry. you still have 8GB of memory. Maybe there's a compatibility issue with the blackberry software recognizing your music. I don't think there is a major problem with anything here.
3. You could try erasing the music off of it to see if the software will recognize it as 8GB, if it does then its because of reason #2
There you go Just my thoughts as to what you could do to troubleshoot you issue. If you have anymore questions just let me know!
-hopeufixit-!
Dec 01, 2010 | Cell Phones
My Blackberry Curve 8330 won't format a media car
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card.
Display the menu and click Format Card.
  • some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
  • A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue.
    If the Format Card option does not appear on the menu, complete the following steps:
  • On the Media Card screen, set the Mass Storage Mode Support field to Off.
  • Display the menu and click Save. The Media Card screen closes automatically.
  • Click Media Card to reopen the Media Card screen.
    To format the media card, display the menu and click Format Card.
Nov 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cannot play Blackberry 9000 mp3 files on Bluetooth devise
Complete the following steps:
1) Use a search engine or a dedicated download site to find and download a third-party conversion tool. The tool must have the ability to convert the format of the audio or video file to a file format that the Media application can read.
2) Install the third-party conversion tool and follow the program instructions to convert the audio or video file to a format that the Media application supports. Refer to the following tables for optimal settings in the Media application.
Optimal settings for the Media application on the BlackBerry 9000 series smartphones:-
For video setting's
a) Video format: MPEG-4.
b) Video file extension: .avi
c) Resolution (4:3): 240x180
d) Resolution (16:9): 320x180
e) Video bitrate: 400 Kbps
f) Frames per second: 24
For Audio settings:-
a) Audio format: MP3
b) Audio bitrate: 128 Kbps
c) Sample rate: 44 kHz
d) Channels: 2 (Stereo)
Transfer the audio or video file from the computer to the BlackBerry smartphone using one of the following methods:-
1) Using BlackBerry Desktop Manager.
Note: BlackBerry Desktop Manager 4.2 must be installed on the computer.
  1. In BlackBerry Desktop Manager, open BlackBerry Media Manager.
  2. Use the Media Manager tool to transfer the audio or video file to the BlackBerry smartphone using a USB connection.
  3. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card, or directly to the internal BlackBerry smartphone memory.
Note: Files larger than 3 MB cannot be transferred to internal BlackBerry smartphone memory.
2) Using the BlackBerry smartphone as a USB mass storage device:-
  1. On the BlackBerry smartphone, go to Options > Advanced Options > Media Card.
  2. Make sure that Mass Storage Mode Support is set to Enabled.
  3. Connect the BlackBerry smartphone to the computer and follow the prompts on the BlackBerry smartphone.
  4. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  5. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
Using a media card reader
  1. Make sure that the media card reader is connected to the computer.
  2. Insert a media card into the media card reader.
  3. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  4. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
  5. Insert the media card into the BlackBerry smartphone.
Oct 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
When i put my media card in my blackberry it says its not there?
back up first all of your files.then format your media card using your Blackberry,not your PC.If it is still same problem after formatting,try to replace another media card and check if other media is working in your phone.lastly,if still not working its already a hardware problem,its a memory card IC,not working anymore,you must replace it.
Jul 22, 2009 | RIM BlackBerry Pearl 8100
Blackberry Disk no longer works. need disk error checking utiliy
your best bet is to format the media card. just insert it into a computer and then right click the drive that is assigned to it and format it. be forewarned that this will erase all of the data on your card!
Jul 11, 2009 | RIM BlackBerry Pearl 8100
SanDisk 2GB memory card
format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
Apr 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Can't download music from my PC to the Blackberry Curve
Go to the options, then click media card, scroll to Auto Enable Mass Storage and set to prompt. Unplug your BB from USB and plug it back in. It will prompt you with a message "Do you want to turn on Mass Storage Mode? Click yes. Don't click Don't ask this question again. I actually came here to find the solution, then i figured it out. Your "Disk Drive" added will then say Blackberry.
Nov 09, 2008 | RIM BlackBerry Curve 8310 Smartphone
Blackberry pearl
when you sync your prgrams on the desktop, click and drag it ouyt of the memory card and onto blackberry
May 10, 2008 | RIM BlackBerry Pearl 8100
My media card
How to view or access media files on the microSD memory card - Mini Secure Digital (miniSD) Memory Card RIM BlackBerry Pearl 8100
To view or access media files on the microSD memory card, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Media.
    • NOTE: To select, press the trackball.
  3. Scroll to and select one of the following folders:
    • Music
    • Video
    • Ringtones
    • Pictures
  4. Scroll to and select Media Card.
NOTE: If the files transferred to the microSD memory card (media card) are not visible, turn on mass storage for the media card:
To turn on or turn off mass storage for the media card, follow these steps:
NOTE: If you receive the error message 'enable mass storage' on the handheld, follow the steps below.
  2. Scroll to and select Options.
  3. Scroll to and select Advanced Options.
  5. Scroll to and selelct Mass Storage Support.
  6. Select On or Off.
  7. Press the red End key to return to the Home screen.
NOTE: If the memory card is unreadable, you may need to format the memory card.
If you have anymore questions just ask me.
Apr 23, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
169 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
