Question about Boating
I have a 1994 150 hp Yamaha outboard motor with tilt-trim. My motor is stuck in the up tilt position and will not tilt down. It is working when I go up, but not down. I have talked to a used parts dealer and a tilt-trim replacement is $425. I also need to know how to install the replacement. How do I remove the pin that goes through the tilt piston? Help!
  • 86 Answers
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Posted on Aug 03, 2009
Will low fluid level cause power trim/ tilt go not hold position
Low fluid level will cause it to fail to actuate and not go up or down, can also let it not hold position as well. Filling to proper leevel with specified lubricant is recommended. If you allow the level to go too low, the pump will pull air and could burn out.
Sep 21, 2014 | Yamaha Tilt Trim Motor, 40-90 HP Outboards...
Outboard problems
Broken connection in the wiring harness(loose)
Jul 28, 2014 | Yamaha Tilt Trim Motor, 40-50 HP Outboard
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
Jul 20, 2014 | Arco Yamaha Outboard Power Tilt and Trim...
How to remove tilt and trim motor
well you have to remove it from the boat first . then remove the side plates to get to the trim tilt unit .
Jul 10, 2014 | Boating
How to replace the mamuel relief value on a 90 hp yamaha out board motor
You have to remove starboard transom bracket,then remove circling from t/tilt release screw,remove screw,left hand thread.There is a flat washer that normally sticks to screw/valve,this needs to be replaced.Its easier to do this with motor trimmed up or if motor is off boat,lying on its side.Very little oil will come out if done in trimmed up position
Mar 29, 2014 | Light Outboard Motor Boat Bass Fishing...
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Aug 31, 2009 | Boating
Boating Logo
762 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
