Question about GE Energy Star WCVH6260F Front Load Washer
After a load it makes a sound and as if the door
After a load reaches the last minute right after the last spin cycle it makes a buzzing sound as if the door is trying to get unlock but door is unlocked but then will not reset for a new load.(button are not responsive) If it is un plugged for a few days the machine will once again turn on, control lights and buttons will be resposive and it's ready for a new load. This happens after 4 to 5 washes regularly.
  • 240 Answers
Your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Posted on Jul 19, 2009
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front loading washer won't spin.
I removed the lower front panel. There's a manual inside and I used the instructions to retrieve the error code. The code indicated a door latch problem. I couldn't do much about that, so I ignored it & kept looking. I completely removed the rubber drain fitting. Inside I found 2 quarters and an underwire from a bra. It was really hard to put back together again - I used a small pair of vise grips to keep each clamp open while slipping the rubber over the plastic fittings. To my amazement, this fixed my problem! All I need to do now is cancel the service appointment.
Sep 01, 2009 | Kenmore Washing Machines
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
148 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
