Question about Dell Optiplex GX110 (2909T) Motherboard
My dell optiplex GX110 motherboard problem
My dell optiplex GX110 motherboard suddenly cannot detect any IDE drive..
Gx110 handleiding problums plz help me
Posted on Jan 20, 2012
  • 585 Answers
I would suggest defaulting the bios, either by way of the cmos jumper, or by entering the bios at boot, selecting "load defaults" from the menu at the bottom of the screen, save and exit. If setting the defaults does not fix the onboard IDE then you have a hardware failure. They make IDE adaptors that plug into a PCI slot, that could get you back into operation, but I'm afraid if the IDE has gone on the mobo, what's next? I would be afraid something else will fail.
Maybe you'll get lucky with the defaults.
Posted on Jul 14, 2009
  • Bruce Volkers
    Bruce Volkers Jul 16, 2009
    One more thing occurred to me. If the mobo has SATA connectors, it may disable the ATA when the defaults are set. If that is the case, you will simply need to enable ATA in the bios.
Cd rom detection problem on optiplex gx110
have you checked to see if the cd drive is showing up in MY COMPUTER?
if it's not the it's possible that the cd drive needs to be replaced
Apr 04, 2012 | Dell OptiPlex GX110 PC Desktop
Hi,I have a Dell Optiplex 280 Desktop Computer.The problem is that it can not detect IDE DVD Ram and IDE Hard drive at one time, while I try to instal an operating system its DVD Ram faills and hard drive...
check your IDE cable if its working or attach properly so the device will be detected, also check the power supply socket that series on each drive,might some wire not properly inserted or might the power supply itself is the problem.
Jun 26, 2011 | Dell Optiplex GX280 (99301) Motherboard
I have tried to change the ram and every thing but the computer wont boot up only ends with an orange light thats all.
always place the ram with the biggest closest to you CPU central processing unit and try to keep it the same brand/type if you have done this to no satisfaction
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 19, 2010 | Dell Optiplex GX110 (2909T) Motherboard
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
HOW MUCH RAM CAN GX110 CAN SUPPORT
This model can handle up to 512 MB of RAM , this is a link for the complete details of this unit.
http://www0.dealtime.com/xPF-Dell-Optiplex-GX110-GX110
Apr 28, 2010 | Dell Optiplex GX110 (2909T) Motherboard
I cannot locate the ide cd rom drive in the bios setup of a dell gx110 what should i do
restart and boot in bios and press F9 then F10, shot down and check for jumper it must be slave when connected parallel with hdd master. start again and check bios if dvd drive detected.
Mar 26, 2010 | Dell OPTIPLEX GX 110/200 PIII-733MHz 256MB...
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell Optiplex Gx280 - cant detect two IDE hard drives
You should attach two hard drives on primary ide. Set both jumpers to cable select ( or one on end is master, middle one is slave). The one at the end of the cable is where your o/s should be. You could try putting the third on seconday, along with your dvd rom.
Hank
Jun 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
Cannot find primary drive 0 (C:)
Make sure the boot sequence is set to look for the hard drive first and also make sure that the hard drive is set to cable select and is the only hard drive on the IDE cable and is plugged into IDE slot 0 on the motherboard.
Nov 15, 2007 | Dell OptiPlex GX110 PC Desktop
Type of RAM for Dell Optiplex gx110
the easiest thing to do is go to crucial.com and click scan my computer, and it will tell you which type of ram your motherboard takes http://www.crucial.com/
Jun 22, 2007 | Dell Optiplex GX110 (2909T) Motherboard
Dell Optiplex GX110 (2909T) Motherboard Logo
359 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
