Question about HP LaserJet 4600dn Color Printer
INSTALLED NEW CYAN CARTRIDGE. MESSAGE ON SCREEN ''CARTRIDGE NOT SEATED OR INSTALL NEW CARTRIDGE'' HELP
    President:
  • HP Master
  • 1,447 Answers
It is the problem your cartridge instalation or assembling see your printer cartridge install manual and then solve
Posted on Jul 14, 2009
When I try to print I get a message CANNOT PRINT. Cannjot detect Cyan in k. BUT i have3just PR4OPERLY installed a BRAND NEW BROTHER CARTRIDGE. I have received this message at least 3 times.
ok go to the brothers icon and double click on it run setup, they have a section for it after you install new cartridge. this will set it . might read "install new cartridge" as a caption
to the machine it doesnt know the cyan was replaced and still reads empty
Sep 21, 2010 | Brother Computers & Internet
Epson Cartridge wont be recognised by printer
Check for the tape that wraps all the way around the cartridge bottom it usually has a red line on one end like a tab DONOT REMOVE THE ONE THAT LOOKS LIKE WIRES ON IT.... is it still there if so remove it.............MAKE SURE THE CARTRIDGE IS SEATED PROPERLY IT DOESNT TAKE ALOT OF STRENGTH TO INSTALL.....
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Cartridges Not Engaged message on screen after replacing yellow cartridge. Had Disabled the old cartridge before replacing in order to keep printing. HELP
The 10.92.YY CARTRIDGES NOT ENGAGED error has 2 digits represented by the YY. These indicate the cartridge that has the issue and are:
00 Black
01 Cyan
02 Magenta
03 Yellow
Steps to follow in sequence and test after each one is completed are:
  1. Open and then close the front door.
  1. If the message persists, make sure all the print cartridges are seated correctly.
  1. Clean the contacts on the memory controller PCA.
  1. Make sure that connectors J302, J303, J304, and J305 on the memory controller PCA are seated correctly. Also make sure that connector J1020 on the DC controller is seated correctly.
  1. Replace the memory-controller PCA if it is damaged.
  1. Check the gears on the print-cartridge drive motors. Replace defective motors.
  1. Replace the DC controller.
Sep 22, 2009 | HP LaserJet 3600n Printer
When I replace the cyan cartridge with a new one I keep getting the message"No Cartridge"
hi!!! in that kind of problem maybe the sensor of the cartridge was damage thats why the sensor cannot detect when you install the cartridge. Try another cartridge or maybe try the to re-install old one if the printer detect the old cartridge that means the new cartridge was defective. Thanks
May 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP LaserJet 4600dn Color Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
