Question about Sport & Outdoor - Others
How to get floorboards in- what order and side pieces?
  • 2 more comments
  • davidikaufma Jul 14, 2009
    this is for a2000 West Marine Zodiac inflatable boat - model SB 285
    i sent info- what is solution?
    can you find manual that explains how and in what position you put boards and in what order?
    prior answers no help !
  • davidikaufma Jul 15, 2009
    there were no specs there - only a bill from used inflatable boat dealer !
    am i to call him?
  • 3,230 Answers
Yes call him......
Please do rate this solution.
Good Luck!!
Thanks
Posted on Jul 15, 2009
  • 3,037 Answers
Hi
I'm sorry that no one has responded sooner but could you be a little more specific on what you are looking for. We are not sure what kind of floorboards you are looking for and what purpose they are for.
Benjamin
Posted on Jul 14, 2009
  • Benjamin Patri
    Benjamin Patri Jul 14, 2009
    There are inflatable floors - the floor is at a
    much higher pressure than the rest of the boat so that they provide a
    firm walking surface, although they are still not as resilient as wood
    floors to abuse from sharp objects.
    There are also roll-up floors - a combination of narrow wood slats and
    rubber/pvc. Probably somewhere between an inflatable floor and a solid
    floor in resilience. Very convenient for constant breakdown/setup.
    Then you have fiberglass floors. Very heavy/expensive and not for
    packing up, but gives you more like a real boat in performance.
    Overkill for tender duty.
    Your #1 decision is whether or not you want/need to break down the boat
    frequently. A lot of inflatables get inflated and stay that way. In
    that case the plain old wood floor is still good value. You only have
    to deal with assembly once.
    So it all depends on how you use it. Boatstogo sells an inflatable floor. Might want to contact them for fitment.http://www.boatstogo.com/AirPlywoodFloor...
    Benjamin
  • 1,272 Answers
I have the pdf for specs. Visit the link below to download the same:
http://www.yousendit.com/download/cmcxanZtRSs4aVBIRGc9PQ
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
  • Anand Gupta
    Anand Gupta Jul 15, 2009
    Well you may contact that dealter to get info for the specs.
Water is running under my dash onto floorboard in my 2007 dodge caliber after it rains. Where is the water comming from
You need to find the conduits for rain - one of them has a leak in it probably from corrosion. Try to locate just where the water is getting in and see if you can use a sealer to stop the water from getting in.
I would remove the glove box and anything else in the way and look for the source when hosing down the car.
Nov 22, 2015 | 2007 Dodge Caliber SXT Sport Hatchback
How to fix water pooling on my floorboard?
To check your doors for leaking close the door on a piece of paper. It should stay in place, no slipping and should be fairly firm to remove with the door closed. To tighten them up, open the door and hold it open while pressing in on the top. It wont take a lot. Try again with the paper. If the doors are good then you need to look at the windshield and rear window as the culprits. they will need to be looked at by a glass installer and repaired there.
Aug 30, 2014 | Cars & Trucks
2005 buick lesabre AC hose plugged leaking water onto passenger floorboard. How do I fix this?
You need to find the drain pan line that comes through the firewall. Open the hood and search for the line on the passenger side firewall. The line is probably clogged from insects, animals, or other gunk. use a short piece of dowel or wire to unclog the line and allow the pan to drain to the outside of the vehicle.
Saab 93 2001 steering rack broken free on driver side
I think there is no such kit, but finding a body shop somewhere in the northern United States that specializes in Saabs would be your best bet.
I have had this problem with several vehicles, caused by rusted out floorboards from salt on the road in winter. I have successfully fabricated a patch for the rotted floorboard and attached the steering rack on 3 cars, none Saab.
It takes finding a suitable piece of steel and forming it to fit the floorboard, the attaching the rack to that. I have done that under the front center of the car, not inside.
Be blessed in your quest.
Jun 17, 2013 | Cars & Trucks
My floorboard keeps getting wet on my chrysler town and country. I had my heater core replaced, but it is still doing it.
Next time it is raining, take a flashlight and look up under the dash to locate the source. Rain that falls into the air intake at the base of the windshield has to drain somewhere. The factory sealant may not be working or there may be leaves clogging the drainage path. Put a piece of newspaper on the floor under the heater core location and run the engine with the heater turned on to detect leakage which may migrate to the driver's side. If this is the source, you should be able to smell antifreeze.
Sep 04, 2012 | 1997 Chrysler Town & Country
A/C leaves cold water in floorboard
Sounds like the HVAC compartment drain is clogged. It is located on the firewall in the engine compartment, on the passenger side. It is a short rubber hose, clean it with a piece of wire hanger or a pencil.
Jul 19, 2012 | 2004 Chevrolet TrailBlazer
How to bypass heating metrix in 2002 eclipse
take a piece of pipe and connect the heater hoses together that will bypass the heater corre
Jun 10, 2012 | 2002 Mitsubishi Eclipse
Water leaks onto the passenger floorboard during heavy rain
Floor plug or plugs have fallen out most likely.There Should be some plastic plugs under the floor board outside. Look to visualy check to insure they are still in one piece.
A busted heater core will flood the passenger side floorboard when the heat is turned on.
Feb 22, 2011 | 1997 Ford Escort
H2o
The drain tube for the a/c is probably plugged. if you can find the tube where it comes out under the hood,usually on the passenger side low on the firewall. Use a piece of wire and clean it out. This should solve your problem.
May 27, 2008 | 2002 Dodge Stratus
Sport & Outdoor - Others Logo
180 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
