Question about GE Spacemaker JVM1640SJ Microwave Oven
Overcooked potato overcooked the microwave
My husband microwaved a potato for 5 minutes which turned out to be probably 50 minutes and during the cooking fell asleep. Beside the lump of charcoal and smoke the oven now is dead. No power. The breaker did not trip. Is this case hopeless? Can it be fixed or is a new oven the solution.
  • GE Master
  • 9,098 Answers
The magnetron probably overheated, blowing the thermal cutout / thermal fuse / thermostat mounted on it.
If you or a friend decide to look into it, we have critical safety and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
Why is my microwave so erratic?
The internal controller may be defective.
Feb 06, 2015 | In Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
Put a potato in microwave it caught on fire dish broke no power to the microwave...did I kill it for good or is there a reset button on it...the microwave in build into my cabinets back of microwave is...
When cooking a potato in the microwave Without puncturing it with a fork... it definitively EXPLODS braking the CAROUSSEL PLATEAU and probably damaging some delicate electronics inside, (you have to pearce the potato with a fork to let steem out when cooking) if you are lucky it could be just a blown fuse inside, have it checked by a proffessional (there is normally no reset for a microwave oven exception maiby for the control panel)
Jan 14, 2011 | GE Microwave Ovens
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Potato caught fire during cooking. Microwave has
Hello, inside most microwaves, there is a thermal fuse, that if something in the cooking cavity is on fire, it will melt the thermal fuse, if it gets hot enough, thus breaking the power to the unit shutting it off. This sounds like what has happened to yours, simply replacing it will correct the problem. It is usually located near a cavity exhaust point. If you aren't comfortable doing this, as it requires removing the outer cover, while unplugged, and locating/replacing it, take it to a appliance service co. This will of course cost more, if you do it yourself, make sure you provide all of your make/model/serial/anything else, that will identify your unit, and call/go online to a parts retailer, and you should be able to get it done fairly cheap.
Hope this helps, and thank you.
Mar 01, 2009 | Microwave Ovens
Microwave light
my kenmore microwave model # 66222, doesn't let the steam out, its ventilated so I know thats not the problem, smells like its burning then shuts off and doesn't come back on until its cooled off, this happened when cooking a Baked Potato, also when I cook something for over 5 minutes
Aug 13, 2008 | Microwave Ovens
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
379 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
