SOURCE: Retrieve a deleted phone number
If you delete the number in your phone phone book and you use SIM card then there is nothing to worry, just retrieve it from your SIM but if it is in your main phone memory then only one lucky way is check your recent call history to see the delete number is still there or check on call out numbers and received numbers. Only those areas which you may be able to retrieve. Good Luck
SOURCE: Umm... reformat nokia 5200. HELP! (I might need more than that!)
use 3 key format (calling+*+3) press all in off state and press on/off button with all keys yur sreen shows forn\matting till
SOURCE: Can I retrieve deleted texts on LG Neon GT365?
It cannot be retrieved withouth opening the phone.
SOURCE: my memory cad for my
don't worry, you can recover lost files from phone's memory card
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech data recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open asoftech data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your data.
SOURCE: Retrieving Deleted photos
You may try this photo recovery which helped me before. You can download trial for free
http://www.asoftech.com/apr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
