Question about Sony STR-DE675 Receiver
When I use a coaxial cable from my DVD player into the Coaxial input in the unit, I get pic but no sound, and yes I have set the input mode to coaxial. Graeme
  • 2 more comments
  • gta24101 Jul 14, 2009
    when I set it to ADF it should automatically it should detect what mode of input is being used. but it still doesn't work,
    Even when I set it to ADF which should automatically detect the input mode it still dosn't work. my DVD player doesn't have optical so I can't try that, the surround speakers are working, (Test tone). Yes I do realise the Coaxial and optical is for the sound only.
  • gta24101 Jul 15, 2009
    Thanx for your reply, I have found the problem, the player was given to me second hand and I just presumed it had been set up, but it had NOT been set up for digital, I don't have the book, so I just changed it for another one and away it went, it found the coaxial digital straight away and now have full surround sound.
  • Mico Dukic May 11, 2010
    Coaxial is for sound, not for picture. You set input mode to coaxial, but maybe you also need to set signal type from "analog" to "digital".
    Problem Solver:
  • 17 Answers
On some DVD players you have a option to set coaxial out in different variants
Posted on Dec 17, 2009
I have the panasonic SC-HT400 receiver which I've connected to a bluray DVD player using an digital coaxial cable mainly because I have no other outputs on the blue ray dvd. As you know the Ht 400 does...
Press the SFC MODE switches at the same time to enter the "settings".
Change these settings to suit the connections you have made to the three digital input terminals, COAX, OPT1 and OPT2, so that the correct source is selected when you turn [INPUT SELECTOR].
The factory settings are: CD: COAX
DVD: OPT 2
TV: OPT 1
If you are allowed change them all to Coaxial. That should solve the sound problem.
Jun 30, 2017 | Panasonic Audio Players & Recorders
My receiver will not change to digital play ? the text on the receiver is ''analog only''
Hi
A little more information about the make and model of your amplifier would make it much easier to tell you exactly what button where to press on your amplifier.
But I am sure I can point you in the right direction.
Analog only means that although you have connected your DVD player or Settop box to your amplifier on the digital coaxial input you have not yet setup all that needs to be setup.
Start by checking that you have enabled the digital coaxial output on you DVD player. You can set the following if it is available:
1: Select your Digital output to ON
2: Dolby Digital setting must be Dolby digital
3: MPEG switched to MPEG, not PCM
4: Select 96Khz/24bit or higher data transfer on coaxial cable.
Note - all these setting might not be available depending on the manufacturer.
Now you will already know the input switching on the amplifier - so select DVD.
Now to activate the coaxial port you must look for a button named "input mode" either on the amplifier itself or on the remote.
Press this until the amplifier says Digital.
Now get ready for great sound.
Hope this helps!
Jan 01, 2010 | Audio Players & Recorders
I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Dec 21, 2009 | Pioneer VSX-D510 Receiver
No sound output from coaxial port on philips dvdr 3475
try setting your av signal selector to auto. if that daes not work go to your av set click on digital input setuo an make sure you have got one of your coaxial slots asigned to dvr1. you will get better sound by using a coaxial or optical hookup compared to hdmi. i've tryed both. hope this helps you , if it don't email me back at mirbrts5@bellsouth.net. i also has a ppioneer av reciever, so i've been through the same trile and errors
May 02, 2009 | Philips DVDR3475/37 DVD Recorder
Toshiba D-VR610KU
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
Dec 22, 2008 | Toshiba DVR610 DVD Recorder/VCR
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Sony STR-DE675 Receiver Logo
302 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
