Question about Dometic Rooftop RV Air Conditioner
Replacing fan motor on a roof top unit, has a thru shaft and was sent both replacement fan blades, can not get the squirrel cage off the evaporator end, not enough room to get your hand in there. this is the rapid cool unit by Domentic,and is on a mountaineer 5th wheel
    Scholar:
  • 91 Answers
If I have both blades and double ended motor, I just use a hacksaw and snip and cut the old one out. If inaccessable you can probably hammer the shaft from the other end, I can't recall if this one has a belly band or not but normally you can tap the shaft right through the armature.
Posted on Jul 14, 2009
Unit vibrates bad and is not fan or fan motor on roof top
need to check squirrel cage on evaporator end of fan motor shaft.
Aug 19, 2015 | Heating & Cooling
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Shaft is stuck in the squirrel cage in swamp cooler how do i get it out?
If you are planning to replace the shaft;
if your able to loosen the 2 square headed bolts( which must be done to allow for shaft movement) do so, then after bearings and pulley are off emerycloth (smooth no burrs or rust) the shafts 2 ends and get grinder and cut thru the shaft on the inside of squirrel cage area as close to the edge of cage as possible drive the shortened pieces of the shaft inward( oil this pieces to help ease movement thru blower wheel) until they are removed replace shaft with new shaft and re-install parts and or replace as needed bearings and blower wheel. I am getting ready to do this very job myself ( take measurements of shaft on each side to ensure your back where you started when done)
May 28, 2012 | Mastercool 67680 Evaporative Cooler Air...
How do you get the squirrel cage off the motor shaft. I bought a replacement motor but it looks like I have to destroy the press fit retaining washer and or the plastic squirrel cage to get the assembly...
I have done this before and it is hard. (big time)One time I just got annoyed and bent the washer and got a replacement one at the hardware store. Sometimes the nut will come off if you pull it gently while "unscrewing" it Try a little WD40 on the shaft to help the squirrel cage off. also prying up gently helps. Good luck.
Jun 10, 2011 | Broan-NuTone QT100L Fan
How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Aug 05, 2010 | Tower Aloha Breeze Fan
The squirl cage on the dryer of my model LSE7806
Howdy,
Absolutely should be positively "locked" to the motor shaft. There should be a set screw in the collar of the squirrel cage mount. Either it is missing of has loosened. Please tighten (or replace) this set screw. Also, it is very IMPORTANT to make sure that if there is a flat machined surface on the motor shaft, that you align the squirrel cage (and set screw) so that the set screw will seat firmly and squarely against this flat surface. This design ensures that once properly aligned and set, that the squirrel cage will follow the motor shaft faithfully. Also, it is recommmended to apply some thread sealant (Locktite) to the threads of the set screw so this will not happen in the future. Vibration can be the cause of this.
Good luck,
J
Oct 20, 2009 | Maytag LSE7806A Top Load Stacked...
Fan on Carrier roof top ac makes loud noise on auto or high but not on low
this one is carrier AC with bad blower motor. Hope This Helps.
Sep 29, 2009 | Heating & Cooling
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
263 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
