Question about Panasonic DMR-EZ28K DVD Recorder
My dvd recorder just 'froze' up, it will not open/close, it will not turn on/off . It said I had a problem with a disc (that is now stuck inside) and that I needed to push the 'ok' button. It would not let me eject the disc, it would not let me turn off the machine. I had to push the ok button, it was the only thing that worked. Now it is totally frozen.
Manually hold down the power button for 10 seconds. This will reset the machine.
Posted on Dec 03, 2009
  • 158 Answers
YOU NEED TO REMOVE THE DISC MANUALY.STRIP THE LOADER AND THEN RESTART THE UNIT
Posted on Jul 27, 2009
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Disc tray frozen in closed position
Unplug it for a few minutes to reset it and then plug it back in again.
Apr 29, 2008 | Samsung DVD-R130 DVD Recorder
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
Jul 10, 2009 | Televison & Video
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Opens and closes
more likely to be a worn belt or in need of lubrication. could maybe have a disc or other object stuck inside try turning upside down and shaking it out.
Oct 28, 2007 | kawasaki SVP500 Multi-disc DVD Player
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Panasonic DMR-EZ28K DVD Recorder Logo
333 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
